Startup Tune for the Project Truck
#21
Think of a fluorescent light bulb. You flick the switch, there is a period of dead time and then the light comes on. If you had that light on a timer and needed it to come on at an exact time, you'd have to know how long it will take from the point that the switch is flicked until the light comes on and flip the switch early. Same thing with the injectors...
#22
Not directly. Yes, this table is key to getting the injectors to open the right amount to idle correctly, but it's not the only factor, and shouldn't be tuned like a VE table. The dead time of an injector is a function of the injectors design, the PCM has no control over it. This is just how the PCM handles that mechanical dead time.
What I'm trying to do is get a list of tables I'll need to modify to run the 60lb Mototrons for a break-in period.
#26
This table defines how much airflow is needed at idle to maintain your desired idle RPM. PCM has idle trims that it will use to add or subtract from this value to achieve idle.
#27
Looks like dc_justin and Kysilverado just hit the nail on the head for your questions. Justin, thats a good expanation concerning the light I was trying to think how to explain it.
Moregrip- If your offset values and Min pulse are out of wack then changes to you VE table at idle will have little to no effect. Are you runing SD or MAf I dont remember?
#30
I'm definitely on the KISS format
