service airbag soon!!!
Old Jan 14, 2011 | 06:33 PM
4.8silvy2004's Avatar
Default service airbag soon!!!
hey guys so i installed new seats in my silvy over the weekend and swaped over all the sensors and now the stupid service airbag soon display and liight is on is there anyway possible without taking it to the dealer to reprogram it or shut it off ???
Old Jan 14, 2011 | 06:46 PM
viciousknid's Avatar
Where's the Beef?
Did you unplug your battery while you were swapping everything?
Old Jan 15, 2011 | 03:34 PM
yea battery was unplugged thanks. anyone else?
Old Jan 15, 2011 | 03:37 PM
Where's the Beef?
Did you swap in New sensors or used ones? Is it possible one of the ones you swapped in is bad?
If they can be reprogrammed it would have to be done with a Tech II at a dealer. Most small shops won't touch an airbag issue with a wooden stick.
Old Jan 15, 2011 | 03:44 PM
i just swapped the factory ones to the new seats and dealer whats 120 just to hook it up to the comp! i have a efi scan tool on my laptop could i use that?>
Old Jan 15, 2011 | 03:52 PM
will the disable procedure for SIR system work ??? and how do u do it?
Old Jan 17, 2011 | 03:42 PM
so i tried sir procedure but still didnt work what happens if i leave the sir fuse out ? is it safe because it shuts off the service airbag soon writing and light thanks
Old Jan 17, 2011 | 04:51 PM
Tech 2 or a shop with a scanner that can talk to the SIR system is your only hope. Otherwise you are just going in circles.
Old Jan 17, 2011 | 05:03 PM
thanks
thompson
Dec 27, 2017 06:48 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
RustyD
May 23, 2016 07:04 PM
Closer_2001
Sep 24, 2015 09:15 PM
fortune46x
Sep 16, 2015 08:18 AM
