Riddle me this... Strange IDC jump
Old Aug 27, 2012 | 10:53 AM
nonnieselman's Avatar
i havent tried..
ill flash in my old pre meth tune and see..
Old Aug 27, 2012 | 11:03 AM
03sierraslt's Avatar
You running a MAF or 2barSD? OL or CL? Just trying to determine what all is playing with your fueling.
Old Aug 27, 2012 | 11:05 AM
2bar OLSD
Ill check the FP in the higher rpms when i run this tank of gas out.
Old Aug 27, 2012 | 11:14 AM
Atomic's Avatar
I have a gauge for that
I want to see what your pulsewidth is doing...
Old Aug 27, 2012 | 11:18 AM
2bar OLSD
If the fuel pressure is dropping then it will be going lean, it has no way to correct. As Atomic said, I also wonder what your PW is doing.
Old Aug 27, 2012 | 11:27 AM
ill try and upload my last log also.. goin to lunch in 30 min....
Old Aug 27, 2012 | 01:50 PM
ok so no jump drive....
heres a quick screen shot.. looks like 117% IDC and 25ms pulse.
Old Aug 27, 2012 | 05:19 PM
lglowe's Avatar
Only thing that makes since to me is you said you added in 5* more timing. That makes a good bit of more horsepower and you can't make more horsepower without more fuel. My opinion... ; )
Old Aug 27, 2012 | 09:51 PM
Area47's Avatar
idc is what the ecm is commanding the injectors to do. doesn't necessarily mean it's out of injector.
check fuel pressure. just because it was fine yesterday doesn't mean it's going to be fine days later. my guess is your pump is dying.
Old Aug 28, 2012 | 04:11 AM
Did you lean it out and find when you were done that it was at 120% or did you lean it out and it was lower then now all of a sudden it really high?
