Rich from colder weather?
Old Nov 19, 2008 | 08:15 PM
2ktransam's Avatar
Default Rich from colder weather?
I am running a speed density tune that I set up in 60 degree ambient temps. Now that the air temp is in the 30's I am running really rich. I made some changes to table A0014 tonight and got it back in line but I don't understand why it goes rich with cold weather. I thought that the cold air was more dense which should make it run lean, right?
Old Nov 19, 2008 | 08:27 PM
nonnieselman's Avatar
what about your A0008 table?
i dont have that problem.. mine stays pretty consistant.
Old Nov 19, 2008 | 08:30 PM
phasemaster1's Avatar
yeah cooler weather should run leaner
Old Nov 19, 2008 | 08:57 PM
2ktransam's Avatar
I have A0008 set to 1.0 after the ECT reaches 40* C.
Old Nov 19, 2008 | 08:58 PM
2ktransam's Avatar
The weird thing is it is running leaner in boost by a half point but richer by a point every where else.
Old Nov 20, 2008 | 07:36 AM
KLUG'S SS's Avatar
FormerVendor
That is weird in colder temps you will go leaner usually. I still have my wideband hooked up and I noticed since it got colder my truck leaned out some.
Old Nov 20, 2008 | 07:50 AM
dewmanshu's Avatar
Moderately Differentiated
CCT (cylinder charge temperature) bias, you will go richer when it is cooler in speed density part throttle (USUALLY, all setups vary obviously).
Cowboy Tom
24
Feb 11, 2017 08:20 PM
GMCtrk
Jan 27, 2016 06:47 PM
Chavette
Oct 28, 2015 07:33 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Closer_2001
Sep 24, 2015 09:15 PM
