Rev Limiter too limited.
Old Apr 10, 2006 | 01:23 PM
Full_Pull6.0HD's Avatar
Default Rev Limiter too limited.
I hope this is the correct section to ask this question. I am trying to raise the rev limiter as high as possible on my Predator for truck pulling. so I raise the rev limiter and the shift point. Even if i put the truck in first gear, it still cuts of at 5500. Is there something going on with like a governer in the transmission or something? I know with most shift improver kits, the advertise hold gears to any rpm. Is this what I need? Any help would be much appreciated. And yes I already know there is no power up there in the 6500+ range, I am just looking for additional momentum so as the weight comes on the sled I am moving faster without being out of first gear. Thank you.
Old Apr 10, 2006 | 04:16 PM
Nick™'s Avatar
there's two rev limiters on your truck, make sure you adjust the one for "ETC" (electronic throttle control), otherwise you aren't doing anything
Old Apr 10, 2006 | 09:57 PM
I didn't know that... It makes sense though. Thank You. I tried to get a hold of DiabloSport today but was on hold my entire break.
Blwn99x
Mar 24, 2023 11:14 AM
Infernohoe
48
Oct 2, 2015 10:25 PM
nic351
Sep 24, 2015 09:43 AM
fortune46x
Sep 16, 2015 08:18 AM
TAPyvehc93
Sep 14, 2015 01:22 PM
