Replaced battery, low idle??(02 Silvy 5.3)
Old Nov 30, 2007 | 08:25 PM
cuisinartvette's Avatar
Default Replaced battery, low idle??(02 Silvy 5.3)
Hey guys, first post.
I have an 02 with 91k. I replaced the battery yesterday and upon startup the idle was superlow, maybe 2-300 rpm?!
Never done this before, has always run flawless. Since yesterday sometimes when starting it the ilde seems ok in park but when it goes to D it does it again. Irritating to say the least.
Volts gauge reads as it always has, just over 14.
Tell me this will reset itself, Im out of warranty and out of work for 6 mos.
Is there a procedure I can do to fix this? I replaced the original batter a few years ago and had no issue.
Thanks
I looked at the stickys and FAQ but if the answer was there I couldnt find it.
Old Nov 30, 2007 | 08:52 PM
TURBHOE's Avatar
try cleaning your idle air control valve. not sure how the battery and low idle would corespond. unless there was a check eng code with no light and when you swaped batteries it erased it. so now the truck has to figure it out again. i would start with the idle air.
Old Dec 1, 2007 | 08:54 AM
jknox's Avatar
When you yanked the battery you reset all of the fuel trims and the learned adaptive idle settings. I'd give it a couple more days and see if it settles down.
Old Dec 1, 2007 | 10:01 AM
TURBHOE's Avatar
oh yeah those too. lol but i would still clean the idle air. it may have adapted to it being cloged.
Old Dec 1, 2007 | 11:23 AM
Ill get some cleaner and make an attempt at it today, I sure appreciate the feedback.
Old Dec 1, 2007 | 11:14 PM
04silverado912's Avatar
Had the same problem a few months back on my truck, cleaned the throttle body and it fixed it. Check that out also
Old Dec 3, 2007 | 01:59 AM
Well, day 3 and it seemed t clear itself up and is back to normal. (whew!) Ill take your advice and clean the IAC and TB anyway, Im sure it needs it,.
Any favorite replacement plugs (spark) you guys like to use? Truck is stock so dont need anything too fancy.
Old Dec 3, 2007 | 06:49 AM
TURBHOE's Avatar
just regular ole ngk plugs tr55. their like 2.50 a piece i think. stay away from bosch and stuff like that. many people have had bad luck with those.
Old Dec 4, 2007 | 03:52 PM
budhayes3's Avatar
PT's Slowest Truck
Glad it cleared up, but just so you know for future reference, sometimes when the battery goes dead or is disconnected, the idle will fluctuate until the computer relearns itself. There is an "idle learn" procedure that can be done (can't remember what it is), but basically just driving it and beating the snot out of it will work lol.
Can't hurt to clean the throttle body anyway, it, along with the IAC and passages can get very gummed up with carbon over time. I usually clean my throttle body once a year as routine maintenance, along with an induction service such as running Seafoam through the intake via the brake booster hose.
BKnBLK05
Dec 28, 2015 08:52 PM
ou812sm
14
Jul 27, 2015 04:38 AM
ou812sm
Jul 23, 2015 02:11 PM
atxlt
Jul 20, 2015 11:06 PM
