Rear 02s
Old Jun 20, 2006 | 08:45 PM
nonnieselman's Avatar
Default Rear 02s
Ok i got a quick question for you guys..
Im fixin to order a Eaton LSD and 4.10s..
but while im recovering from that and saving up for the LT headers and ORY pipe, could i gut my cats and turn my rear O2's off with EFI Live and pick up any power with the stock manifolds??? I have replaced my stock muffler with a 6"Rd magna flow.
If so where do i go in EFI Live to turn them off at?
and is there anything else i need to change?
Thanks Guys!!!
Old Jun 20, 2006 | 09:05 PM
LesPaul's Avatar
you can turn off the rear o2's but its not going to get any power what so ever... only thing the rear ones do is check to make sure the cat is working right
Old Jun 20, 2006 | 09:10 PM
even if i gut the cats? just wondering
Old Jun 20, 2006 | 11:58 PM
LesPaul's Avatar
im sorry i think that i missread your post... you will gain some power by gutting the cats..... makes it flow better but in all honesty your stockers flow good not sure if you will notice the power that you will gain
Old Jun 21, 2006 | 08:44 PM
ok.. i wont worry bout it then.. ill wait for the LTs and ORY. Thanks LesPaul!!
But ill still need to turn off the Rear O2s when i get the LTs...
How do i do that with EFI Live???
Old Jun 21, 2006 | 10:20 PM
LesPaul's Avatar
i dont have any idea how to turn them off in efi live i dont use it
Old Jun 22, 2006 | 12:33 AM
thunder550's Avatar
High on diesel fumes
A couple things to change:
Engine Calibration -> Cat Converter -> Catalytic Converter Protection Enable: {Disable}
Engine Diagnostics -> Engine DTC Processing Enablers -> P0137 "O2S Circuit Low Voltage Bank 1 Sensor 2": {X: Not Reported}
Engine Diagnostics -> Engine DTC Processing Enablers -> P0138 "O2S Circuit High Voltage Bank 1 Sensor 2": {X: Not Reported}
Engine Diagnostics -> Engine DTC Processing Enablers -> P0140 "Circuit Insufficiency Activity Bank 1 Sensor 2": {X: Not Reported}
Engine Diagnostics -> Engine DTC Processing Enablers -> P0141 "O2S Heater Performance Bank 1 Sensor 2": {X: Not Reported}
Engine Diagnostics -> Engine DTC Processing Enablers -> P0157 "O2S Circuit Low Voltage Bank 2 Sensor 2": {X: Not Reported}
Engine Diagnostics -> Engine DTC Processing Enablers -> P0158 "O2S Circuit High Voltage Bank 2 Sensor 2": {X: Not Reported}
Engine Diagnostics -> Engine DTC Processing Enablers -> P0160 "Circuit Insufficiency Activity Bank 2 Sensor 2": {X: Not Reported}
Engine Diagnostics -> Engine DTC Processing Enablers -> P0161 "O2S Heater Performance Bank 2 Sensor 2": {X: Not Reported}
Engine Diagnostics -> Engine DTC Mil Enablers -> P0157 "O2S Circuit Low Voltage Bank 1 Sensor 2": {No Mil}
Engine Diagnostics -> Engine DTC Mil Enablers -> P0158 "O2S Circuit High Voltage Bank 1 Sensor 2": {No Mil}
Engine Diagnostics -> Engine DTC Mil Enablers -> P0160 "Circuit Insufficiency Activity Bank 1 Sensor 2": {No Mil}
Engine Diagnostics -> Engine DTC Mil Enablers -> P0161 "O2S Heater Performance Bank 1 Sensor 2": {No Mil}
Engine Diagnostics -> Engine DTC Mil Enablers -> P0157 "O2S Circuit Low Voltage Bank 2 Sensor 2": {No Mil}
Engine Diagnostics -> Engine DTC Mil Enablers -> P0158 "O2S Circuit High Voltage Bank 2 Sensor 2": {No Mil}
Engine Diagnostics -> Engine DTC Mil Enablers -> P0160 "Circuit Insufficiency Activity Bank 2 Sensor 2": {No Mil}
Engine Diagnostics -> Engine DTC Mil Enablers -> P0161 "O2S Heater Performance Bank 2 Sensor 2": {No Mil}
Old Jun 22, 2006 | 03:16 AM
Derek @ EDO's Avatar
FormerVendor
nope, gutting the cats with stock manifolds will not make a noticeable difference.
Old Jun 22, 2006 | 10:58 PM
Thanks Thunder, DLH2006, and LesPaul..... i got that saved now...
So basically all that does is.... it wont read the rear 02s and then disable the MILs so the SES light wont come on??
Old Jun 23, 2006 | 01:17 AM
thunder550's Avatar
The O2's will still report to the PCM but it won't do anything based on what it reads from them, meaning that it won't set a DTC or SES light if the readings aren't what it is expecting.
BCraven1018
37
Dec 20, 2016 11:46 AM
Corvette454l88
Sep 1, 2016 01:24 AM
YenkoST
Aug 28, 2015 01:42 PM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
