Rafig Pids
Old Oct 19, 2010 | 11:28 AM
viciousknid's Avatar
Where's the Beef?
Default Rafig Pids
I'm still working on getting my friends 4.8 tuned. It has the cruise control effect when you let off the brake. It just takes off.
This is typically cured by tuning the Desired Airlow in Gear with the RAFIG process. However I can not get the idle trims to activate. They stay X'd even after logging has started.
This would be any of the IAT-Long term/Short Term correction pids.
Anyone know why I can not get them to read?
Vehicle is a '99 Silverado 4.8 4l60 214/220 110lsa. Idle AFR is about 15:1 and timing at idle is 20-23
I've increased and lowered B4307 in large and small increments and see minimal response.
Old Oct 19, 2010 | 11:40 AM
BlackGMC's Avatar
Resident Retard
What i just did was log the grams/sec directly from the MAF instead of using the idle trims. I suppose you could use the Calc pid for the map sensor todo the same thing for the SD
Old Oct 19, 2010 | 11:53 AM
BlackGMC's Avatar
Resident Retard
Posting up the tune would probably help
Old Oct 22, 2010 | 07:10 PM
Where's the Beef?
I'm going to go through the VE tomorrow and make sure it's good since I haven't spent a whole lot of time on it with the wideband. But for the Desired airflow do you still add the readings to the table when using the Maf G/S like you do the stit/ltit's?
Old Oct 22, 2010 | 08:10 PM
Where's the Beef?
I'm testing your MAF theory out on my truck so that When I get to his I know what to do. I turned my MAF back on and was only getting a reading of 1.58g/s. Does this mean My MAF is bad or could there be another issue? I'm pretty sure the wires are hooked up but I'll double check.
Old Oct 22, 2010 | 08:54 PM
BlackGMC's Avatar
Resident Retard
No you dont add them, the numbers in the log you just copy and paste them into the table. But themwhole process requireamthe maf table to be tuned/ calibrated
Sounds like your maf is bad or you maf table is horribly off
Old Oct 22, 2010 | 09:10 PM
Where's the Beef?
The mad table is stock. I've never touched it. Plan on using it again tho so I'll try another maf.
AkSSS
Mar 29, 2016 11:03 PM
BlackGMC
Aug 14, 2008 09:54 PM
kbracing96
Apr 20, 2007 10:37 PM
Whippled 496
14
Nov 20, 2006 06:11 AM
