Quick Question!!!
Does anyone have a wiring schematic of the computer pins for an 2001 GMC Yukon if it matters the motor is a 6 liter!!! If someone could share that with me I would really appreciate it!!!
Powertrain Control Module (PCM) C1 (BLU)
Connector Part Information
• PCM Connector C1 Assembly 12191489
• TPA (BLU) 12176408
• Connector Cover 12191108
Pin
Wire Color
Circuit No.
Function
BLK/WHT
451
Ground
LT GRN
1867
12 Volt Reference
PNK/BLK
1746
Fuel Injector 3 Control
LT GRN/BLK
1745
Fuel Injector 2 Control
5-10
Not Used
11
LT BLU
1876
Knock Sensor 2 Signal
DK BLU/WHT
1869
CKP Sensor Signal
13
ORN/BLK
463
Requested Torque Signal
14
ORN/BLK
1061
UART Serial Data [Secondary]
DRK BLU/WHT
774
UART Serial Data [Tertiary]
16
Not Used
17
DK BLU
1225
Transmission Fluid Pressure Switch Signal B
18
RED
1226
Transmission Fluid Pressure Switch Signal C
19
PNK
439
Ignition 1 Voltage
20
ORN
440
Battery Positive Voltage
21
YEL
1868
Low Reference
22
Not Used
23
PPL
719
Low Reference
24
Not Used
25
TAN
1671
HO2S Low Signal [- Bank 2 Sensor 1]
25
TAN
413
HO2S Low Reference (Denso Sensors) HO2S Low Signal (Delphi Sensors)
26
TAN
1667
HO2S Low Signal [- Bank 2 Sensor 2]
26
TAN
413
27
Not Used
28
TAN/WHT
1669
HO2S Low Signal [- Bank 1 Sensor 2]
28
TAN
413
29
TAN/WHT
1653
HO2S Low Signal [- Bank 1 Sensor 1]
29
TAN
413
30
LT GRN
1478
Coolant Level Switch Signal
31
Not Used
32
BLK/WHT
771
Transmission Range Switch Signal A
33
PPL
420
TCC Brake Switch Signal
34
WHT
776
Transmission Range Switch Signal P
35
GRA
48
CPP Switch Signal
36
BLK
1744
Injector 1 Control
37
YEL/BLK
846
Injector 6 Control
38
PNK/WHT
1101
Damping Lift/Dive Signal
39
Not Used
40
BLK/WHT
451
Ground
41
BLK
407
Low Reference
41
GRA
720
Low Reference (w/o Delphi HO2S)
42
Not Used
43
RED/BLK
877
Fuel Injector 7 Control
44
LT BLU/BLK
844
Fuel Injector 4 Control
45
GRA
474
5 Volt Reference (FTP Sensor)
46
GRY
474
5 Volt Reference (TPS Sensor)
47
GRY
597
5 Volt Reference (MAP Sensor)
48
GRA
596
5 Volt Reference (EGR Sensor)
49 50
Not Used
51
DK BLU
496
KS [1] Signal
52
Not Used
53
BLK
470
Low Reference
54
BLK
452
Low Reference
55
BRN
1456
EGR Valve Position Signal
56
Not Used
57
ORN
440
58
DK GRN
1049
ECM/PCM/VCM Class 2 Serial Data
59
YEL
710
Class 2 Serial Data
60
ORN/BLK
469
Low Reference
61
PNK/BLK
632
Low Reference
62
Not Used
63
GRA
720
Low Reference
63
TAN
413
64
Not Used
65
PPL
1670
HO2S High Signal [- Bank 2 Sensor 2]
66
PPL
1666
HO2S High Signal [- Bank 2 Sensor 1]
67
Not Used
68
PPL/WHT
1668
HO2S High Signal [- Bank 1 Sensor 2]
69
PPL/WHT
1665
HO2S High Signal [- Bank 1 Sensor 1]
70
BRN
1174
Oil Level Switch Signal
71
Not Used
72
YEL
772
Transmission Range Switch Signal B
73
BRN/WHT
633
CMP Sensor Signal
74
YEL
410
ECT Sensor Signal
75
PNK
1020
Off/Run/Crank Voltage
76
BLK/WHT
845
Fuel Injector 5 Control
77
DK BLU/WHT
878
Fuel Injector 8 Control
78
Not Used
79
WHT
687
3-2 Shift Solenoid Valve Control
80
ORN/BLK
510
Low Reference
Pin
Wire Color
Circuit No.
Function
BLK/WHT
451
Ground
LT GRN
1867
12 Volt Reference
PNK/BLK
1746
LT GRN/BLK
1745
5-10
Not Used
11
LT BLU
1876
DK BLU/WHT
1869
CKP Sensor Signal
13
ORN/BLK
463
14
ORN/BLK
1061
DRK BLU/WHT
774
16
Not Used
17
DK BLU
1225
18
RED
1226
19
PNK
439
Ignition 1 Voltage
20
ORN
440
21
YEL
1868
Low Reference
22
Not Used
23
PPL
719
Low Reference
24
Not Used
25
TAN
1671
25
TAN
413
26
TAN
1667
26
TAN
413
27
Not Used
28
TAN/WHT
1669
28
TAN
413
29
TAN/WHT
1653
29
TAN
413
30
LT GRN
1478
31
Not Used
32
BLK/WHT
771
33
PPL
420
34
WHT
776
35
GRA
48
CPP Switch Signal
36
BLK
1744
Injector 1 Control
37
YEL/BLK
846
Injector 6 Control
38
PNK/WHT
1101
39
Not Used
40
BLK/WHT
451
Ground
41
BLK
407
Low Reference
41
GRA
720
42
Not Used
43
RED/BLK
877
44
LT BLU/BLK
844
45
GRA
474
46
GRY
474
47
GRY
597
48
GRA
596
49 50
Not Used
51
DK BLU
496
KS [1] Signal
52
Not Used
53
BLK
470
Low Reference
54
BLK
452
Low Reference
55
BRN
1456
56
Not Used
57
ORN
440
58
DK GRN
1049
59
YEL
710
Class 2 Serial Data
60
ORN/BLK
469
Low Reference
61
PNK/BLK
632
Low Reference
62
Not Used
63
GRA
720
Low Reference
63
TAN
413
64
Not Used
65
PPL
1670
66
PPL
1666
67
Not Used
68
PPL/WHT
1668
69
PPL/WHT
1665
70
BRN
1174
71
Not Used
72
YEL
772
73
BRN/WHT
633
CMP Sensor Signal
74
YEL
410
ECT Sensor Signal
75
PNK
1020
76
BLK/WHT
845
77
DK BLU/WHT
878
78
Not Used
79
WHT
687
80
ORN/BLK
510
Low Reference
Powertrain Control Module (PCM) C2 (RED)
• PCM Connector C2 Assembly 12191488
• TPA (RED) 12176410
Pin
Wire Color
Circuit No.
Function
BLK/WHT
451
Ground
BRN
418
TCC PWM Solenoid Valve Control
TAN
1465
Fuel Pump Relay Control [- Secondary]
Not Used
TAN/BLK
464
Delivered Torque Signal
RED/BLK
1228
PC Solenoid Valve High Control (Sol. A)
RED
1676
EGR Valve Supply Voltage (5 Volt)
LT BLU/WHT
1229
PC Solenoid Valve Low Control (Sol. A)
DK GRN/WHT
465
Fuel Pump Relay Control [- Primary]
WHT
121
Engine Speed Signal
11
DK BLU
604
A/C High Pressure Recirculation Switch Signal
Not Used
13
LT BLU/BLK
396
Cruise Control Engaged Signal
14
Not Used
BRN
25
Charge Indicator Control
16
GRY/BLK
1694
4WD Low Signal
17
DK GRN/WHT
2523
A/C Request
18
Not Used
19
BLK/WHT
1695
Axle Switch Signal
20
LT GRN/BLK
822
VSS Low Signal
21
PPL/WHT
821
VSS High Signal
22
RED/BLK
1230
AT ISS High Signal
23
DK BLU/WHT
1231
AT ISS Low Signal
24
Not Used
25
TAN
472
IAT Sensor Signal
26
PPL
2121
IC 1 Control
27
RED
2127
IC 7 Control
28
LT BLU/WHT
2126
IC 6 Control
29
DK GRN/WHT
2124
IC 4 Control
30
Not Used
31
YEL
492
MAF Sensor Signal
32
LT GRN
432
MAP Sensor Signal
33
DK GRN
1614
Recirculation Actuator Control
34
DK GRN/WHT
428
EVAP Canister Purge Solenoid Control
35
Not Used
36
BRN
436
AIR Pump Relay Control
37-38
Not Used
39
RED
631
12 Volt Reference
40
BLK/WHT
451
Ground
41
WHT
257
EGR Solenoid Control
42
TAN/BLK
422
TCC Solenoid Valve Control
43
DK GRN/WHT
459
A/C Compressor Clutch Relay Control
44
Not Used
45
WHT
1310
EVAP Canister Vent Solenoid Control
46
BRN/WHT
419
MIL Control
47
YEL/BLK
1223
(2-3 Shift Solenoid or Shift Soleniod B) Valve Control
48
LT GRN
1222
(1-2 Shift Solenoid or Shift Soleniod A) Valve Control
49
YEL/BLK
1827
Vehicle Speed Signal
50
DK GRN/WHT
817
VSS Signal
51
YEL/BLK
1227
TFT Sensor Signal
52
GRA
23
Generator Field Duty Cycle Signal
53
Not Used
54
PPL
1589
Fuel Level Sensor Signal [- Primary]
55
DK GRN
603
A/C Low Pressure Switch Signal
56
Not Used
57
BLK
552
Low Reference
58-59
Not Used
60
BRN
2129
Low Reference
61
BRN/WHT
2130
Low Reference
62
GRA
773
Transmission Range Switch Signal C
63
PNK
1224
Transmission Fluid Pressure Switch Signal A
64
DK GRN
890
Fuel Tank Pressure Sensor Signal
65
Not Used
66
PPL/WHT
2128
IC 8 Control
67
RED/WHT
2122
IC 2 Control
68
DK GRN
2125
IC 5 Control
69
LT BLU
2123
IC 3 Control
70-71
Not Used
72
BLK/WHT
3122
HO2S Heater Low Control [- Bank 2 Sensor 1]
73
DK BLU
1936
Fuel Level Sensor Signal [- Secondary]
74
LT GRN/WHT
3213
HO2S Heater High Control [- Bank 2 Sensor 1]
75
Not Used
76
LT GRN/WHT
1749
IAC Coil B High Control
77
LT GRN/BLK
444
IAC Coil B Low Control
78
LT BLU/BLK
1748
IAC Coil A Low Control
79
LT BLU/WHT
1747
IAC Coil A High Control
80
LT GRN
3212
Pin
Wire Color
Circuit No.
Function
BLK/WHT
451
Ground
BRN
418
TAN
1465
Not Used
TAN/BLK
464
RED/BLK
1228
RED
1676
LT BLU/WHT
1229
DK GRN/WHT
465
WHT
121
Engine Speed Signal
11
DK BLU
604
Not Used
13
LT BLU/BLK
396
14
Not Used
BRN
25
16
GRY/BLK
1694
4WD Low Signal
17
DK GRN/WHT
2523
A/C Request
18
Not Used
19
BLK/WHT
1695
Axle Switch Signal
20
LT GRN/BLK
822
VSS Low Signal
21
PPL/WHT
821
VSS High Signal
22
RED/BLK
1230
AT ISS High Signal
23
DK BLU/WHT
1231
AT ISS Low Signal
24
Not Used
25
TAN
472
IAT Sensor Signal
26
PPL
2121
IC 1 Control
27
RED
2127
IC 7 Control
28
LT BLU/WHT
2126
IC 6 Control
29
DK GRN/WHT
2124
IC 4 Control
30
Not Used
31
YEL
492
MAF Sensor Signal
32
LT GRN
432
MAP Sensor Signal
33
DK GRN
1614
34
DK GRN/WHT
428
35
Not Used
36
BRN
436
37-38
Not Used
39
RED
631
12 Volt Reference
40
BLK/WHT
451
Ground
41
WHT
257
42
TAN/BLK
422
43
DK GRN/WHT
459
44
Not Used
45
WHT
1310
46
BRN/WHT
419
MIL Control
47
YEL/BLK
1223
48
LT GRN
1222
49
YEL/BLK
1827
50
DK GRN/WHT
817
VSS Signal
51
YEL/BLK
1227
TFT Sensor Signal
52
GRA
23
53
Not Used
54
PPL
1589
55
DK GRN
603
56
Not Used
57
BLK
552
Low Reference
58-59
Not Used
60
BRN
2129
Low Reference
61
BRN/WHT
2130
Low Reference
62
GRA
773
63
PNK
1224
64
DK GRN
890
65
Not Used
66
PPL/WHT
2128
IC 8 Control
67
RED/WHT
2122
IC 2 Control
68
DK GRN
2125
IC 5 Control
69
LT BLU
2123
IC 3 Control
70-71
Not Used
72
BLK/WHT
3122
73
DK BLU
1936
74
LT GRN/WHT
3213
75
Not Used
76
LT GRN/WHT
1749
77
LT GRN/BLK
444
78
LT BLU/BLK
1748
79
LT BLU/WHT
1747
80
LT GRN
3212
SWINGRRRR
Sep 3, 2015 07:49 PM
mr03silverado
Sep 2, 2015 11:43 PM
