Question on a 411 PCM swap
Old Nov 29, 2014 | 06:57 PM
Sevex's Avatar
Snail Fab
Default Question on a 411 PCM swap
I have been doing some reading on the 99-00 PCM vs the 01-02 pcms. I have a 2000 rcsb with a 5.3 that I will be doing a turbo build on.
I am mainly concerned about the false knock issues people are having with the early pcms and would also like the extra tables that come with the later pcms.
My main question, I was planning on running a 3bar SD operating system through HP Tuners, would I still run into the false knock issues running that OS on the early PCM? Or since I am changing the OS I will get rid of that issue?
Should I swap to the newer PCM and then do the 3bar SD OS?
Hope this question makes sense
Thanks!
Old Nov 29, 2014 | 07:29 PM
Do yourself a favor and swap to the 411 ecm been there done that. I wasted a 200 bucks worth of credits on my 99 ecm with the 2 bar os upgrade. Swap now. It also doesnt cost any more to upgrade to a 3 bar after you purchase the 2 bar.
Old Nov 30, 2014 | 12:09 AM
George C....'s Avatar
Formerly ScreamingL
depending on the OS you can do a write entire to a new OS if you have the means to, this will get you everything of a newer pcm
Old Nov 30, 2014 | 02:09 AM
Chevy_freak's Avatar
It's usually not the OS that's the problem. It's hardware related, so swapping to the newer PCM fixes several issues at once.
Old Nov 30, 2014 | 10:43 AM
Formerly ScreamingL
youre not understanding what i had said. Depending on the OS of the early pcm you maybe able to do a write entire with a newer OS from a 02 truck. This would prevent you from having to buy another pcm
Old Nov 30, 2014 | 10:28 PM
Sevex's Avatar
Snail Fab
Ok so I guess now the question is what OS would allow me to do that?
And is the never PCM a direct plug and play deal? (Assuming same engine trans config)
And did they change in 01? So any 01-02 would work or just an 02?
XL7
May 5, 2022 01:48 PM
Bluchevypick
Aug 18, 2015 09:11 AM
USMCvet0311
Aug 1, 2015 07:45 AM
chvy=power
Jul 27, 2015 10:06 AM
GreyChevy
Jul 7, 2015 08:57 PM
