Problems with tune and codes? Help ASAP!! EFI live
Old Mar 15, 2010 | 05:55 PM
gao8302's Avatar
Default Problems with tune and codes? Help ASAP!! EFI live
I just put some 60lb injectors in my truck (sieman deka 60's). Thats the only thing that changed from last year..the truck has been parked for the winter. Now I keep getting Code P0103 and P0353. P0353 is Ignition control circuit and P0103 is MAF Circuit High. Im running a COS3 with the MAF disabled. I drove the truck yesterday with the MAF turned on and it drove fine. Today i was running the MAF disabled. I changed Table C2907 and C2908. But now if i load my tune that has the MAF enabled the truck runs really lean. Whats the problem. I spent all day yesterday tuning the IPW B3701 and the Main Ve table for the injectors and all was good. So i dont understand what the problem is???
Also the Code P0353 keeps popping up. I thought it was a bad Coil pack...so i switched it to cylinder #5 and the code keeps popping up for cylinder number 3. So then i switched the spark plug wires around and i still have the problem.
Im going crazy with this guys because i cant drive my truck to work because of it. So any help would be awesome. Im including my Tunes for the truck..they are EFI live.
This is the tune with out the tables changed for the MAF (C2907 & C2908). It has the 4 at the end.
The other one has the MAF disabled. Tune with the 5 at the end.
ARC
57
Feb 21, 2022 10:54 AM
shawn96gmc
May 17, 2016 04:15 PM
kr1s
Aug 24, 2015 05:34 PM
black00chev
Jul 31, 2015 04:33 PM
GMCtrk
Jul 17, 2015 06:39 PM
