Problem with truck not wanting to go into PE?
Old Apr 11, 2006 | 08:49 PM
ASkipper's Avatar
11 Second Club
Default Problem with truck not wanting to go into PE?
I have tried out some things I was told to do to get my truck to go into PE sooner.I changed the MAP to 90,Hyst to 2 and the delay rpm to 1000. It stills act the same.When I do 0-100 mph blast it will only go into PE when it changes into 2nd gear. What gives am I missing something. I believe I read a post on HPtuners site that Allen Nelson had a problem just like this with an 06 it just did not post what the fix was.
Old Apr 11, 2006 | 09:14 PM
FarmTruc's Avatar
Performance Trucks Sponsor
I was in the same boat with these 2 '06 turbo trucks I had here. Contact support at HPT, send them your file and they'll fix it. There is another value in the '06 trucks that delay PE mode. Added to the latest update from HPT, there's a new value that is set at 100%, if you don't have the latest update, get it and try that.
After the fix, both '06 trucks went into PE mode as soon as I commanded it.
good luck,
allen
Old Apr 11, 2006 | 09:19 PM
ASkipper's Avatar
11 Second Club
Thanks Allen.I have an e-mail in to them now.
Old Apr 11, 2006 | 09:40 PM
ASkipper's Avatar
11 Second Club
Just got the e-mial back from HP.Looks like more tuning and logging tommorrow night to see if that is the fix.
Old Apr 11, 2006 | 09:55 PM
1slowsilverado's Avatar
Hmm very intersting. did you just get a software update or did you have to send your .Bin to them? Keep us updated.
Old Apr 11, 2006 | 11:11 PM
Zick's Avatar
Why are you raising the MAP to 90? Mine stock is only 55 and I've now got it at 0 just to have one less thing to worry about for getting into PE.
Old Apr 12, 2006 | 06:51 AM
ASkipper's Avatar
11 Second Club
They sent me a update.If that does not fix it I will probably have to send them my .bin
Old Apr 12, 2006 | 06:53 AM
ASkipper's Avatar
11 Second Club
I was told to try that also.One thing that bothers me is that with my tune in there it want go into PE,but my stock tune will change time you kick it.
Old Apr 12, 2006 | 10:08 AM
chrisj6's Avatar
There are a few things you have to change. Zero out all the values at the top of that section, so whenever the TPS commands PE, it goes right into it. Also I maxxed the enrichment rate so it gets there the quickest.
Chris
Old Apr 12, 2006 | 10:53 AM
Zick's Avatar
I'm not sure I understand why they would tell you this. If you raise the MAP, that just means now you have to wait until you get to 90Kpa versus 55Kpa before you'll go into PE mode.
I just zero mine out that way all I have to worry about is hitting the TPS % to enable PE.
