PRND Indicator light repair 03 Denali
Old Feb 24, 2013 | 10:28 AM
vandal699's Avatar
Default PRND Indicator light repair 03 Denali
I hope this is the correct section but I cant seem to find the info on repairing/replacing the gear indicator in my cluster. I am a tech and do LOTS of stepper motors and bulbs in these trucks but need to fix my own this time. Info on parts please?
Old Feb 24, 2013 | 11:59 AM
Suburbazine's Avatar
Hard to find, at best. I am fairly certain the display incorporates part of the "brain" for the cluster, meaning that replacement may require reprogramming (or be impossible?). ACdelco will have the parts if anyone does, but that requires some sort of Delco certification to get parts.
If you're lucky, you could find a useable display in a junkyard cluster.
Old Feb 24, 2013 | 12:06 PM
1FastBrick's Avatar
Custm2500's Rude Friend
If you are sure its the cluster, then most likely you have to take it to a speed shop or buy a replacement. Some parts are available but I found they are all tight lipped about it.
Most likely the circuit board will have to be replaced but a new board will require programming.
Choda
Jun 5, 2025 06:43 PM
Idryfly5
Sep 2, 2022 08:55 PM
blowngmc
32
Oct 12, 2017 11:59 AM
carid
Oct 28, 2015 08:24 AM
Justin87gn
Sep 10, 2015 12:06 PM
