P0455 Evap???
Old Oct 7, 2008 | 12:19 PM
RED04REGENCYRST's Avatar
Default P0455 Evap???
anyone know where to start with this problem, or how to fix it?
Old Oct 7, 2008 | 02:15 PM
chevrolet all the way's Avatar
is it an evap leak? large? if so then if you ever had your truck runnnin with the gas cap off itll do it. thats all i know of to be a simple fix
Old Oct 7, 2008 | 03:57 PM
it has only thrown the code a few times. i was getting "tighten fuel cap" across the cluster. so i replaced the gas cap and that didnt fix it. sorry i guess i should have explained alittle more. so anyway im figurin i have a leak but where do i start to look for it? what do i look for?
Old Oct 10, 2008 | 05:54 AM
will a evap leak cause your ltft's to go rich but not affect your stft's? my ltft's are running between -4% at idle with the p0455 cleared from the computer, and -11% when the code is thrown. someone had mentioned doing a smoke test on the evap system.
anyone know how to do this and can walk me through it?
where can i get the smoke test kit?
what bout o-rings for the fittings? (cause that is probably be the problem right?)
Old Oct 10, 2008 | 06:39 AM
Grumpy5.3's Avatar
you could take it to the dealer and let them smoke it.... otherwise a smoke machine is $$$$$.. sometimes you can get under there see residue from the leak, but not all the time.
Old Oct 10, 2008 | 11:41 AM
bigred06's Avatar
Default po455
It'S A LARGE LEAK, TRY CHECKING YOUR HOSE CLAMPS ON YOUR FILLER NECK AND OR IT COULD MEAN YOU HAVE A BAD SEAL AT THE MODULE , YOU COULD TRY PUTTING SOME PRESSURIZED AIR THROUGH THE EVAP LINES AND SOMEONE HEARING THE LEAK BUT IT'S A PAIN
Old Apr 22, 2010 | 02:10 PM
SILVERBIRCH's Avatar
Im bumping this thread because im having the same issue has anyone else experienced this and how did you fix it thanks in advance..
Old Apr 22, 2010 | 03:49 PM
TurboGibbs's Avatar
I have it as well. I've done so many mods to my evap over the years I figured it had something to do with that and haven't had the time to look into it. Mine also throws -11 to -16 LTFT on bank 1 often and has a hessitation at low rpm cruising and accellerating. When it pulls fuel on the LTFT my wideband will show in the 16:1 range on bank 1. Never really thought about the evap causing it. Haven't checked into it. With most of my shop in storage from my move I don't even change my own oil right now.
Old Apr 23, 2010 | 08:06 AM
I also had a "Tighten Gas Cap" message so i just went ahead and bought a new cap but the SES light is still on Im gonna try disconnecting the Battery for a few hours this weekends to see if it turn off.
Old Apr 23, 2010 | 12:48 PM
there is a evap vent back by the gas tank. i talked to a couple of buddies that work for a chevy dealer and there is a part that relocates the evap vent. they claim that the oe setup gets filled full of crap and screws **** up. so i bought it and replaced it and have been code free. sorry i dont have the part number anymore, but any dealer parts counter should know about it.
Corvette454l88
Sep 1, 2016 01:24 AM
Avalanche2002
Nov 30, 2015 07:31 AM
Mr. Chainsaw
Oct 18, 2015 08:00 PM
noproblems209
Aug 10, 2015 06:57 PM
Blackrat48
Jul 12, 2015 07:28 PM
