p0446?
lol. i have read threads about this p0446. and not one thread was finished with i solved the problem.. i really dont wanna buy the part and for the light to come back on thats what all i have been reading..
I just checked the background on this DTC, there are many variables that can cause this DTC to set. Here are some diagnostic aids recommended by AllData.......
DIAGNOSTIC AIDS P0446
-When using the Evaporative Emission System Tester (EEST) to apply pressure, you can regulate the amount of pressure by activating the remote switch ON and OFF while observing pressure in the EVAP system using a scan tool. DO NOT use more than 5 inches H2O. More than 5 inches H2O applied to the EVAP system can cause the canister vent solenoid valve to temporarily remain in the closed position, which could lead to misdiagnosis in this procedure.
-An intermittent condition could be caused by a damaged EVAP vent housing, a temporary blockage at the EVAP canister vent solenoid valve inlet, or a pinched vent hose. A blockage in the vent system will also cause a poor fuel fill problem.
-An EVAP canister, vent hose, or vent solenoid valve that has restricted flow may cause this DTC to set. Using a purge solenoid valve command with a scan tool will allow vacuum to be applied to the system instead of pressure. With the EVAP canister vent solenoid valve open and the EVAP canister purge solenoid valve commanded to 100 percent , vacuum should not increase to more than 9 inches H2O.
