p0446?
Old Dec 6, 2008 | 08:25 PM
oldred95's Avatar
Do you drive in dusty conditions much? We do vent valve and canister jobs like clock work out here in Oklahoma. The EVAP system gets air from the valve thats located under the truck which sucks up dust and dirt. Typically if you have a P0446 you are going to need a canister too because 99% of the time there is dirt contamination in the canister as well. GM has a reroute kit which consists of a different style vent valve and then you take heater hose and run it along the frame and put the remote mount filter box somewhere up in the engine compartment where the air is somewhat cleaner.
Old Jan 2, 2009 | 12:05 AM
AllThrottle4U's Avatar
12 Second Club
What kind of symptoms are you guys getting with a bad evap system? Taking a longer time than normal to start? What about a miss at idle? Just trying to narrow down a problem. Thanks
Old Jan 2, 2009 | 08:30 AM
JAVI05's Avatar
i still havent fixed my truck. i am in need of the relocate kit and sensor. the p0446 has not had any driving or running issues. no miss idle or hard starts just an annoying check engine light.. but runs great.
Old Jan 2, 2009 | 08:34 AM
Wilde Racing's Avatar
How do I change this text
If it's an 07 why not make the dealership fix it?
Old Jan 2, 2009 | 10:58 AM
JAVI05's Avatar
tell me how and i will? 07 classic 65,000 miles. 100,000 mile drivetrain warrenty. can they fix it 4 me?
Old Jan 2, 2009 | 12:00 PM
hmmm, if it smog related you are still covered.... Might try giving them a call...
Old Jan 2, 2009 | 12:27 PM
JAVI05's Avatar
thanks i will call..
Old Jan 2, 2009 | 12:46 PM
JAVI05's Avatar
i called, 36,000 mile only. kinda sucks that when i need something from gm fixed everything else is covered except the part i need... lol..
Old Apr 26, 2009 | 02:18 AM
CashDudeHomie's Avatar
My mom's truck has this code as well. She lives down a dirt road so maybe that has something to do with it. I just set the code to "no MIL" for now. Is this just a smog issue or can anything bad happen from the canister being contaminated?
Old Apr 26, 2009 | 08:36 PM
budhayes3's Avatar
PT's Slowest Truck
It's just an evaporative emissions issue, won't cause runability problems. Worse case scenario is the vent tube gets clogged and you might have problems with the gas pump kicking off while trying to fuel, but that's highly unlikely.
