P0442
Old Sep 20, 2010 | 10:51 AM
williebones's Avatar
Default P0442
I am started getting this code Saturday while on the way back from visiting my mom in West, Tx. I had the local autozone use their reader and get the P0442 code so I pulled the gas cap off and put it back on and made sure it clicked a few times. Normally it takes just a few minutes and the light goes off it is the gas cap. Got all the way back home and the lights still on, same code, so I replace the gas cap with a new one. The SES light is still on, any ideas what my problem is now and how to fix it?
Here is the information on the code:
A code P0442 most likely means one or more of the following has happened:
* A loose or improperly affixed gas cap
* A non-conforming gas cap (i.e. not factory/original brand)
* A small leak/hole in a fuel vapor hose/tube
* Other small leak in EVAP system
* Faulty vent o-ring seal
This is on my 04 Sierra, completely stock other than the intake and vette servo
Old Sep 20, 2010 | 12:56 PM
darnie's Avatar
check the gas cap seal, may need a new one even though u tryed to tighten it. tighten all ur hose fittings, check compression, and pulgs.... what we do at the dealership?
Old Sep 20, 2010 | 02:18 PM
i replaced the gas cap......
Old Sep 20, 2010 | 02:43 PM
Ketis's Avatar
i have the same code, only will come on about 2 times a month. seems to be at random..
Old Sep 20, 2010 | 02:52 PM
SILVERBIRCH's Avatar
Mine use to give me a message saying "tighten fuel cap" i then bought a new one and nothing still was on i got a buddy a the dealer ship to clear it so far it has not came on.
Old Sep 20, 2010 | 04:01 PM
darnie's Avatar
check your hoses, or could even be your canaster????
Old Sep 21, 2010 | 10:44 AM
maybe ill have a local shop do a smoke test
Old Sep 21, 2010 | 11:27 AM
fastnblu's Avatar
I'll guess it's along the lines of 1 of the 2 things in red. This has been on here before, but I never noticed til I had same problem.
Now that this occurred to me, I may be in the clear, cause I cleared the PO442. It wasn't allowing me to pump gas. Did that happen to you, where it shuts off pump?
I had been fighting this for 1-1 1/2 mo. I cleared it & it improved. I'll find out today if it's still an issue if I get gas. IIRC, it's an evap emissions vent solenoid.
budhayes3's Avatar
PT's Slowest Truck
The light will stay on until the EVAP monitor runs again and the system passes the test, there are a bunch of parameters that have to be met for the EVAP monitor to run. I currently have a check engine light with a code P0446 due to a bad vent valve that I haven't had the dough to replace. Every so often the light will go off for a day or two, until the monitor runs again and the system fails. Have the code cleared and see if it comes back...
Old Sep 21, 2010 | 11:38 AM
now that you mention that i was having problems getting gas on Thursday, how much was the vent solenoid?
i also got gas sunday night and did not have any problems, different gas station though
