P0300 code?
Old Sep 7, 2005 | 08:41 PM
JRsilverado's Avatar
Default P0300 code?
I keep getting the P0300 code but only when I'm idleing. I have the POS Bosch+4 (I didn't know at the time). I was wondering, can these be the cause. I know if one is cracked it can but what about a "good" one? I know there are other things I can check also but I felt I should start here.
Old Sep 8, 2005 | 12:15 AM
OUT2WIN's Avatar
My truck had that code and it was the crank relearn.
Old Sep 8, 2005 | 07:52 AM
Thanks. I've already had the crank relearn done.
Old Sep 8, 2005 | 09:31 AM
budhayes3's Avatar
PT's Slowest Truck
Multiple misfire code, could be a number of things. I'd lose the Bosch plugs just for piece of mind and start from there. You can pick up a set of NGK TR55's for less than $2 a plug.
Old Sep 8, 2005 | 11:05 AM
I picked up some TR55s earlier this morning. If I have time this afternoon, I'll change them out. If not, I'll do it tomorrow when I change my front wheel hub Thanks for the help. I hope it works.
Old Mar 1, 2006 | 11:36 PM
fire51's Avatar
Im having the same problem. I changed plugs, wires, fuel filter, and now I'll be changing the cats. how do you do the crank relearn?
Old Mar 2, 2006 | 12:38 AM
dc_justin's Avatar
Hello Dave
For the crank relearn, I hooked up EFI Live to his truck and performed it last summer.
I've had a pretty bad misfire at idle on all cylinders caused by the truck going lean randomly. Think I tracked mine to one of my intake tubing clamps not being completely tightened down.
Old Mar 2, 2006 | 10:07 AM
Zick's Avatar
I believe the cam is causing your false reading on misfires. I did in my case and a few others from what I hear.
You can try upping the misfire time or do what I did and just disable it.
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
Tydriver
45
Oct 23, 2015 09:19 PM
