fuel regulator
Old Feb 28, 2006 | 07:26 AM
z7199's Avatar
Default fuel regulator
Is there a way you can tell if your fuel regulator is going bad? Also is there anyway to upgrade it if it is bad or just go buy a new one?
Old Feb 28, 2006 | 10:28 AM
Mort's Avatar
Cool
You can check your FPR by pulling the vacuum line at the FPR. Run the truck for a bit then shut it down. Pull the vacuum line and check for the presence of fuel. If it is wet then the FPR is bad and needs to be replaced. Just put a new one in it's place.
Old Feb 28, 2006 | 10:58 AM
COLDZ71's Avatar
About how much do they usually go for? I got quoted $67. Does this sound right?
Old Feb 28, 2006 | 09:57 PM
budhayes3's Avatar
PT's Slowest Truck
That's about what mine went for (I payed slightly less since I work at a dealership myself)
Old Mar 1, 2006 | 07:15 AM
z7199's Avatar
Yeah that little sucker is HIGH. what kind of problems were you guys having when it was bad. Mine is wet in there so I am pretty sure it is bad
Old Mar 2, 2006 | 07:29 PM
budhayes3's Avatar
PT's Slowest Truck
I was having hard start issues and running poorly until I drove it and beat on it a bit.
Old Mar 3, 2006 | 07:06 AM
z7199's Avatar
By hard start do you mean it would just keep turning over and over and then it would start and idle funny? for a little bit.
5.3Okasai
Mar 9, 2022 01:07 PM
The_W
Aug 15, 2015 08:07 AM
TAPyvehc93
Aug 8, 2015 06:35 PM
lxcoupe
Jul 21, 2015 02:12 AM
GMCtrk
Jul 17, 2015 06:39 PM
