P01-0411 Has me stumped- no spark/no fuel on different cylinders
Old Mar 15, 2021 | 10:48 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Talking
Originally Posted by arthursc2
So, who's got the magic sauce and the "you're a dumbass, its right here, circuit XXX"? Whatever the deal is, unless its the reluctor, its not mechanical
And Because you asked, I got you something....
Old Mar 16, 2021 | 05:46 AM
arthursc2's Avatar
Old Mar 16, 2021 | 06:30 AM
dantheman1540's Avatar
So this likely has no impact on your issue and maybe It's just something I've never noticed before but I find it odd the indexing mark is not in relation to the counterweights on the cam gear. Or that there are "counterweights" on the cam gear, all the roller masters I've used and stock gears I've seen appear to be symmetrical
P0336 is the only code your getting besides the traction control disabled?
Old Mar 16, 2021 | 06:33 AM
arthursc2's Avatar
P0102 because of SD 3bar, but that's to be expected
The other 2 codes are TC related
Edit: sorry Dan, missed it at first. That gear is the 2x gear because I am using a gen4 cover and sensor on this build because gen4 blocks cant take gen3 sensors
also verified I flipped A and C and have 12v at the cam sensor on A and traced B and C back to the PCM
Old Mar 16, 2021 | 01:16 PM
arthursc2's Avatar
How do Gen3s calculate torque input?
Traction control is calculating torque as -280ft/lbs
Also the car is idling at 36 degrees advance according to the Tech2
Old Mar 16, 2021 | 06:36 PM
RedXray's Avatar
100% Redneck
Is the 3br MAP a gen3 sensor or a gen4 sensor with the bolt type hold down?
Old Mar 16, 2021 | 07:27 PM
arthursc2's Avatar
Its gen4 (ZR1) with appropriate data and wiring
reads 81kpa at KoEo. I think that might be a little low, but I haven't checked my city's kPa yet
Old Mar 16, 2021 | 08:13 PM
MikeGyver's Avatar
81 kPa would be 6000 feet altitude according to this web page.
Old Mar 16, 2021 | 08:45 PM
arthursc2's Avatar
I live ~5500 so we can assume that's reading properly depending on DA
Old Mar 16, 2021 | 09:46 PM
RedXray's Avatar
100% Redneck
Is that sensor used regularly in gen3 vehicles?
During my TBSS intake swap research I found you couldn't use the TBSS Gen4 MAP sensor on a Gen3 vehicle even when using the correct gen4 to gen3 adapter harness without scaling the data in the tune. I'm guessing " appropriate data" means you have scaled the data in the tune. Those that tried the harness adapter alone without changing the tune had running issues and had to lose the adapter harness, then modify the original gen3 MAP sensor to fit the gen4 intake.
