Ok Ok 6.0 stock pcm ??? for pcm guys Help
Old Nov 14, 2007 | 02:57 PM
thunder550's Avatar
High on diesel fumes
THUNDER550
Isnt the 4.8 pcm, different as far as fueling tables exc then the 6.0 pcm. If they are then wouldn't a cammed 6.0 run really bad, all I have on the 4.8 tune is the HYPERJUNK. I was wanting to know if I could use a returnless fuel system pcm on a truck with a return system. I know that a 6.0 pcm will not run that great on a cammed 6.0, but since the 6.0 pcm is for a (returnless fuel sys) will it really run bad I am keeping the return system on the truck.. thanks
John
Your sig says 6.0, I was assuming that you were swapping from one 6.0 to another. I personally would use your original PCM and have a 6.0 tune put in it. How long are you planning on driving it before you have it tuned?
Old Nov 14, 2007 | 03:08 PM
Mangled03gmc's Avatar
Baltimore Whore
Nope still have the 4.8 with the hyperjunk. Not too long hopefully, a month or so, or at least I get money to get a tune for it. I need to get it off the stand and am tired of looking at it, the tune aspect is really all that is holding me up at this point.. So I can get by if it will run with out a tune of verter..
Thanks John
Old Nov 14, 2007 | 04:29 PM
thunder550's Avatar
Thanks John
What cam are you running in the new 6.0? What injectors?
Old Nov 14, 2007 | 06:00 PM
Baltimore Whore
The cam is 581 581 224 on a 112. Also I have the heads milled .20
Thanks John
Old Nov 14, 2007 | 06:02 PM
thunder550's Avatar
Thanks John
Are you using the same injectors from the old engine?
Old Nov 14, 2007 | 06:16 PM
Baltimore Whore
Yes for a short period, but I have a set of 44's lined up. I had a set but sold them mfers, now kicking myself in the ***. If it will run I can drive like a normal human till i get **** in the right direction. Also the stock verter for now, If it will move I will drive it, I am getting tired of looking at this hog in my shop lol. Also thanks fer the help brotha
John
Old Nov 14, 2007 | 07:53 PM
GMC_DUDE's Avatar
Another factor to consider is that the 2005 ECU will have a graduated IFR table to account for the returnless fuel system. This should not cause any serious problems, but should be replaced with a constant table at the next tune.
Go5.3tt06
Sep 12, 2015 09:29 AM
steves86ta
Jul 28, 2015 10:21 AM
chvy=power
Jul 27, 2015 10:06 AM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
