Oil Pressure
Old Oct 26, 2015 | 01:45 PM
WarbirdLS1's Avatar
Originally Posted by 01WS6/tamu
Year make model?
If it's a dod motor check oil pressure at the filter and at the oil pressure sensor simultaneously. then go forward with diagnostics from there
If it's not a dod and a mechanical gauge shows 0 or less oil pump died o ring problem ets
It's a 2000 engine new ported pump and O-ring...just had it down to put the new pump and timing set in it.
Old Oct 26, 2015 | 01:49 PM
It's pump or pump related hardware then oring etc. oil pressure leaves the pump flows down galley drilled down the side of the block into oil filter out of oil filter and directly up to oil pressure sensor the out to valvetrain and mains from there. Oil filter maybe collapsed? But if your mechanical gauge shows low pressure something major with pump happened.
Pull it apart and check bypass maybe but I wouldn't mess with a pump having problems put a new one in it and hope it didn't hurt bearings. It wouldn't be first time I've seen a LS turn cam bearing with same end result also.
Wolftrk99
37
Feb 18, 2017 03:31 PM
kdw8888
Oct 15, 2015 06:29 PM
JordanH
Oct 14, 2015 05:12 PM
Slammed silverado
Sep 28, 2015 06:14 PM
