DOD never kicks in....
Old Oct 26, 2015 | 12:26 AM
Noah Burns's Avatar
Default DOD never kicks in....
so DOD is turned "on" in my tune now, but at one point it was turned off... it use to kick in/out all the time, that's why I originally turned it off. I turned it on a few weeks ago when I was taking a long drive, figured it'd help with MPG... it didn't kick on once... now, when I had it turned on before, the truck was basically stock... now it's got it's and ory and all that stuff with the applicable codes turned off... would any of those codes relate to the DOD system and it's engaging? Any other reason you guys could think of that it wouldn't come on? Maybe just reload the tune?
Old Oct 26, 2015 | 09:51 AM
Atomic's Avatar
I have a gauge for that
I haven't ever messed with DOD, but DFCO is based mainly on MAP and most of the time with a cam change your coasting vacuum and cruising vaccum is way different so that needs to be tweaked so DFCO will work. I know you didn't say you did a cam, but maybe start with checking entry and exit criteria anyway.
Old Oct 26, 2015 | 01:02 PM
stall maybe?. Gotta be a parameter that needs to be tweaked. I dont know what pcm needs to see in order to decide to activate dod mode. The gm description is motor under light load to activate dod. Mods can effect the criteria the pcm usues to determine what exactly light load is
Old Oct 26, 2015 | 09:41 PM
Wheatley's Avatar
Truck Sponsor
Make sure COT protection is enabled!! If it is disabled,DOD will not enable
Hope this helps
Old Oct 26, 2015 | 10:42 PM
03sierraslt's Avatar
Hope this helps
Interesting, thanks for the info.
Old Oct 27, 2015 | 07:40 AM
bigsapper's Avatar
Hope this helps
Interesting, because I know he's running an ORY so he probably has turned it off.
I guess most guys running ORYs are probably turning DOD off too anyway.
Old Oct 27, 2015 | 01:15 PM
Noah Burns's Avatar
that was it... COT was disabled! Wheatley for the win!
with an ORY, what if any issues will there be with leaving the COT enabled?
Old Oct 27, 2015 | 01:24 PM
Just set max enrich to 1.00.
calsdad
Jun 14, 2023 11:07 PM
Chewy07
Nov 14, 2015 09:46 PM
wickedRCSB
Oct 10, 2015 09:29 PM
gmcyukon
Oct 5, 2015 06:20 AM
bisqikss
Sep 27, 2015 09:40 PM
