OBDII won't read with scanner
HP Tuners | EFILive | Hand Held Programmers | Stand Alone PCM's | Electronics | Wiring Diagrams
Mar 23, 2016 | 05:03 PM
Joevc
Registered User
Jan 2016
My OBDII will not read with a scan tool and it doesn't seem like it's getting power. What would cause this? And how do i fix it?
Joevc
Find More Posts by Joevc
Mar 23, 2016 | 06:07 PM
Gadgetized
Jan 2010
Rochester, NY
Check the cig lighter fuse.
Gadgetized
Find More Posts by Gadgetized
Mar 23, 2016 | 10:13 PM
Joevc
Registered User
Jan 2016
Quote:
Originally Posted by
Gadgetized
If the cig lighters work could that still be the issue?
Joevc
Mar 24, 2016 | 03:03 AM
Suburbazine
Feb 2009
Baton Rouge, LA
yes, the cig lighters have separate fuses. The one you want has the actual lighter attached, not the accessory 12v outlets (not heat rated).
Suburbazine
Visit Suburbazine's homepage!
Find More Posts by Suburbazine
Kent Moore 4L80E tool kit complete
Dark Halo
12:56 PM
MAF reading zero
crashmymax
05:21 PM
AFR readings?
crashmymax
07:15 PM
Guidance reading nitrous plugs
GreatWhiteBuffalo
07:11 AM
LS Spring tool in Edmonton needed
roland1
09:57 AM
Back to Subforum
View Next Unread
02 Yukon 80e swap, tuning insight please!
11:24 PM
