obd II port dead
Old Jan 29, 2007 | 11:43 PM
brent5631's Avatar
Default obd II port dead
okay guys. im new but have been reading and lurking for a few months. anyway i have a 99 ecsb and the diagnostic port has gone dead. ive searched through old threads and have already checked the cigarette lighter fuse and it was ok. so if anyone has any other ideas that would be great. thanks guys.
Old Jan 29, 2007 | 11:47 PM
CHEVRACER83's Avatar
check the dome lamp fuse.... and all other fuses.... then get a repair manual, and check for power at the aldl connector with a volt/ohm meter
Old Jan 29, 2007 | 11:57 PM
hrodgmc's Avatar
also check to see if anything has been installed on the ground and 12volt supply wires behind the aldl connector. Some security system installers use this as a means of power.
Old Jan 31, 2007 | 09:01 PM
Manic Mechanic's Avatar
Also check that the wires are in the proper locations compared to a factory wiring diagram. I found one that had a wire in the wrong slot causing a communications failure once.
Vernon
Old Feb 10, 2007 | 06:13 PM
Blucreek's Avatar
cig lighter fuse also
Old Feb 10, 2007 | 07:17 PM
dirtyratt's Avatar
Im with the rest. Allways seems to be a fuse
Old Feb 11, 2007 | 02:06 PM
Flyer's Avatar
Cig lighter fuse ...
They share a circuit.
Old Feb 11, 2007 | 03:31 PM
Sport Side's Avatar
Yeah, I can not use the very right cig. lighter and OBD port at the same time or pop goes the fuse.
dsbodley
Nov 14, 2015 09:46 PM
gmcyukon
Oct 3, 2015 11:03 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
old motorhead
Sep 29, 2015 08:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
