O2 Pin identification. Need help.
Old May 7, 2007 | 10:56 AM
COLDZ71's Avatar
Default O2 Pin identification. Need help.
A friend of mine built a portable LC1 wideband for his 99 Camaro. I would like to use it on my 2002 GMC.
He needs to know what each pin does on my O2 sensor to make it work. His O2s plugins are backwards compared to mine. (male-female) I believe the wire colors are black, black, blue and white.
If anyone can point me in the right direction I would really appreciate it. I am trying to tune for my new cam. I know there is alot left in it.
Old May 7, 2007 | 06:41 PM
Supajut's Avatar
This is the schematic I used on my Camaro to run it through the stock 02:
A = NBO2 Signal Low = LC-1 green
B = NBO2 Signal High = LC-1 yellow
C = Heater Ground = LC-1 blue
D = Heater Power = LC-1 red
Hopefully someone will chime in and tell ya if it applies to your truck, good luck.
J
Old May 7, 2007 | 06:42 PM
COLDZ71's Avatar
Something like that would be perfect.
Old May 8, 2007 | 10:47 AM
COLDZ71's Avatar
No one has messed with the oxygen sensors of these trucks?
Old May 8, 2007 | 11:49 AM
dewmanshu's Avatar
Moderately Differentiated
I let my account at alldatadotcom die so I can't get a schematic, but the above, Supajut's camaro being a '98 doesn't have high and low heater references. I am sure somoeone will hook ya up soon with a good reference. Hit up Innovative's website as well.
Old May 8, 2007 | 04:56 PM
COLDZ71's Avatar
Ok thanks. I will keep looking around. I hope someone has a wiring schematic to show what each wire does. I think we could take it from there.
Old May 8, 2007 | 05:32 PM
joshluther's Avatar
This is the truck side of the harness...
B1S1 Purple/wht= high
Tan/wht =low
Pink = 12v
B1S2 Same as above
B2s1 Tan = Low
Purple =high
Pink= 12v
B2s2 Same as above
Send me some beer
Old May 8, 2007 | 08:49 PM
COLDZ71's Avatar
Tan/wht =low
Pink = 12v
B1S2 Same as above
B2s1 Tan = Low
Purple =high
Pink= 12v
B2s2 Same as above
Send me some beer
Awesome!!! So just to be 100%. Black is ground, correct? What's your favorite lager?
Old May 8, 2007 | 09:05 PM
joshluther's Avatar
Yup black is ground. Sam Adams white ale for now
Old May 8, 2007 | 09:57 PM
COLDZ71's Avatar
Here you go...................
[IMG][/IMG]
