noticed 11 dtc's today
Old Apr 15, 2009 | 05:21 PM
mcfarlnd's Avatar
Un-Registered User
Default noticed 11 dtc's today
im wondering if i have a wiring problem but, before i go wire chasing i figured i would post this up to see if anyone has seen anything similar to this. i have been open loop for a while because my o2s were freaking out, with no success of finding my problem stayed in open loop and left it alone. im wondering if i find the reason for these issues i might fix the o2s.
here is the dtcs list.
[PCM] U1016 - Loss of Class 2 Communication with VCM (History) (Immature)
[Unknown] B1440 - (History) (Immature)
[Unknown] B2961 - (History) (Immature)
[Unknown] U1016 - Loss of Class 2 Communication with VCM (History) (Immature)
[Unknown] U1152 - Loss Of ACM Serial Data Communication (History) (Immature)
[HUD] U1000 - Class 2 Communication Malfunction (History) (Immature)
[HUD] U1016 - Loss of Class 2 Communication with VCM (History) (Immature)
[HVAC] B0263 - (History) (Immature)
[HVAC] B0408 - Temperature Control (Main/Front) Circuit Malfunction (History) (Immature)
[HVAC] B0418 - (History) (Immature)
[HVAC] B1375 - (History) (Immature)
Continuous Tests
Misfire: Complete
Fuel System: Complete
Comprehensive Component: Complete
Once Per Trip Tests
Catalyst: Complete
Heated Catalyst: n/a
Evaporative System: Incomplete
Secondary Air System: n/a
A/C System Refrigerant: n/a
Oxygen Sensor: Incomplete
Oxygen Sensor Heater: Incomplete
EGR System: n/a
Old Apr 15, 2009 | 05:38 PM
dlt76028's Avatar
never seen those codes before what are you doing to that truck?? lol
Old Apr 15, 2009 | 05:43 PM
mcfarlnd's Avatar
Un-Registered User
hahaha, i thought the same thing. it runs great but, it popped all these strange codes and i dont know when. the front wheel speed code has been there since i bought the truck brand new and as for the rest......... i have no clue when they came about. i never look at the dtcs unless i have a problem or checking my readiness tests for inspection.
Old Apr 15, 2009 | 06:45 PM
dirt track racer 81's Avatar
i wouldnt worry about them. looks like body codes did your check engine light come on?
Old Apr 15, 2009 | 06:49 PM
KySilverado's Avatar
I have all kinds of similar codes stored in mine also. No worries.
Old Apr 15, 2009 | 08:59 PM
budhayes3's Avatar
PT's Slowest Truck
Yea, those are body codes, I wouldn't lose any sleep over them...and they have no affect on your O2 sensors
Old Apr 15, 2009 | 09:37 PM
Low_S-10's Avatar
the u code probably set when you reflash the pcm, cause during a reflash none of the other modules can communicate with the pcm. i would just clear them cause there all history
Old Apr 15, 2009 | 09:38 PM
mcfarlnd's Avatar
Un-Registered User
no, the check engine light never came on.
i didnt know if they were on the same circuit or shared a common ground or even somehow shorting each other slightly. you never know what could happen because i have seen some strange stuff. while troubleshooting i never count anything out. thanks for the replies fellas.
RustyD
May 23, 2016 07:04 PM
bearden86
26
Nov 15, 2015 03:58 PM
cheyenne383
Nov 13, 2015 09:24 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
