No lockup on cruise.
Old Oct 7, 2012 | 02:48 PM
urdone's Avatar
Default No lockup on cruise.
Why the truck wont lock on cruise mode?
I try to lick it up in 3rd gear and 4th gear but it wont, if lock it through the scanner it will but not by itself. I have the truck to lock under 45 miles all the way under 50% tps.
The tranny is built with a 3600 PI.
Any suggestions? I have done plenty of truck and they lock with any problem.
Old Oct 7, 2012 | 03:19 PM
03sierraslt's Avatar
But it will lock when not in cruise? If so check your cruise tables to see how they compare to normal.
Old Oct 7, 2012 | 04:07 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You could post the tune file and get better help.
Old Oct 7, 2012 | 04:37 PM
urdone's Avatar
Let me post it up.
Old Oct 7, 2012 | 06:31 PM
urdone's Avatar
I change pcm and it lock up. Maybe something is wrong with pcm
Old Oct 7, 2012 | 06:51 PM
What?
Old Oct 7, 2012 | 07:44 PM
urdone's Avatar
I swap to a different pcm and it work, now it locks on cruise mode.
Old Oct 7, 2012 | 07:45 PM
Did the PCM you swapped to have the same tune loaded into it?
Old Oct 7, 2012 | 10:49 PM
urdone's Avatar
No but it had around the same miles and tps % to lock.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
thunder550
Oct 8, 2015 04:53 PM
turbo6c3
Oct 5, 2015 06:11 PM
maxspeed05V
Aug 26, 2015 04:21 AM
07 z71 silverado
Aug 18, 2006 03:00 PM
