New tires. 2" shorter. Need your help.
Old Dec 13, 2012 | 04:31 AM
custm2500's Avatar
Ph.D. in HUBRIS
Default New tires. 2" shorter. Need your help.
I installed my 20" wheels with a slightly shorter tire last night. The truck loves to sit on the limiter before shifting now. Is tire diameter the only thing I need to change in the tune?
Thanks in advance!
Old Dec 13, 2012 | 08:23 AM
nonnieselman's Avatar
change the tire size so it adjust all the trans shifting tables.
Old Dec 13, 2012 | 08:55 AM
custm2500's Avatar
Ph.D. in HUBRIS
perfect. THanks. Will do.
Old Dec 13, 2012 | 09:24 AM
sprayedenali's Avatar
The rpm/mph will probably be off as well...
Where before if you were wanting to shift at say 6000rpm/55mph now 6000rpm would be at 50mph...
Old Dec 13, 2012 | 09:35 AM
i was hoping when he adjust the tire size it would correct the part and wot MPH shift tables.
Old Dec 13, 2012 | 11:02 AM
Does it do that?? I've honestly never noticed...
Old Dec 13, 2012 | 11:24 AM
EFI live will if you click apply haha..
never fooled with HPT that much.
Old Dec 13, 2012 | 12:00 PM
custm2500's Avatar
Ph.D. in HUBRIS
I have efi live so the tire size will fix the shift tables and everything correct?
Seems to be what I am getting from this but just want to make sure.
Old Dec 13, 2012 | 12:46 PM
ak2007r6's Avatar
It's an option for HPT also. When you change the tire size there is a check box to also scale the trans tables. Does a decent job from what I have seen so far
Old Dec 13, 2012 | 01:00 PM
03sierraslt's Avatar
Both HPT and EFI will auto scale I believe, as mentioned above HPT just has a box you check to do so.
