need 2010 ECM pinout
Old May 8, 2013 | 02:24 PM
BIGDADDY1969's Avatar
Cool need 2010 ECM pinout
I have an E38 ECM pinout for 2008 gm truck and need a 2010 E38 ECM pinout to see what if anything is different between the 2 ... both for 5.3 if that makes any difference ..thanks any help is greatly appreciated..
Old May 8, 2013 | 02:37 PM
Cool
2010 ECM part number 12633238 to be exact ...
the 2008 ECM is part number 12612384
Old May 8, 2013 | 08:52 PM
Bump up .. Need a pinout 2010 ECM or answer if 08 and 10 ecms have same pinouts
Old May 8, 2013 | 11:39 PM
luisdavid11's Avatar
page c-6
http://www.gmupfitter.com/publicat/2...lec_1_7_D1.pdf
Old May 9, 2013 | 12:17 AM
Cool
Im at work .. im permanent nights but i will upload that onto my laptop when i get home ... Im try navigate that n then back n forth to compare the 08 pin out i found but im on mobile n may take a while until i get home on laptop...Thanks ..
Old May 9, 2013 | 01:18 AM
Well thanks to ipad and iphone i had the pin out on each side by side and the ECMs are pinned exactly the same .. Cylinder deactivation order andeverything from the 08 pinout from ls1tech link i found and the 2010 luisdavid just gave me link for.... Now whats the odds that the fuse blocks in both 08 and 10 are wired exact like the ecm plugs are.....?????? On to those charts now........it would seem if the 2 ecm plugs are pinned exactly the same according to the pinouts then it would work. . . . .
Old May 9, 2013 | 01:37 AM
Cool
I pulled up both fuse blocks under hood labels and the posistioning is exactly the same ... The numbers they are labeled slightly off by one or two digits butwhen you look at each fuse on both labels they are both exactly the same word for word in every location ...interesting ... .. ECM arrives Sat i hope ... Til then ive racked my brains enuff ....
Old May 9, 2013 | 01:44 AM
Update ... Iwas looking at an HD fuse block lol so a few numbers were off .. Found my 08 fuse block label and compared to whats in the link listed above from luisdavid for 2010 and it is also perfect ... Im going to double check my actual cover for my fuse block when i get up today and compare it to this 2010 one ... Thats it til then ...
Silver8ado
Sep 30, 2015 11:42 AM
5.3lSilverado
Sep 20, 2015 06:48 PM
brandonrac15
Sep 17, 2015 08:51 PM
chvy=power
Sep 8, 2015 11:06 AM
jleews6
Sep 8, 2015 10:17 AM
