MAF not reading
Old Oct 15, 2018 | 11:09 AM
Drspencer's Avatar
5 Year Member
Default MAF not reading
After a Trans swap back to a 4L60E, my MAF is not reading and throwing P0121.
Voltage at MAF with key on, not hooked to MAF
Yellow 4.97v
Pink .48v
Hooked up to MAF
Yellow 2.21v
Pink .21v
White and black 1.48v
Tan .03v
Removed and reinstalled Volant intake tube to make sure the lip wasn't caught at the bottom side of the throttle body.
Used a can of brake parts cleaner to hose around the intake manifold and sensor holes to see if it bogged, it didn't.
I read on another thread that setting the tune back to stock helped bring it back? No idea.
Mods are
Volant intake
Dynatech long tubes and catted Y pipe
ported and cut 862s
208/212 Comp Cam
Anything I'm missing? Checked the grounds, this is a new issue since I put the cam in 12,000 miles ago.
Old Oct 16, 2018 | 10:38 AM
Pink s/b +12v referenced to gnd with key on. But if you are referencing to the gnd wire on the MAF the gnd could be open. What you are missing in the post is any mention of what the vehicle is.
Old Oct 16, 2018 | 11:56 AM
Drspencer's Avatar
5 Year Member
2008 Avalanche 5.3
Old Oct 16, 2018 | 12:57 PM
Drspencer's Avatar
5 Year Member
Checked voltage from MAF and grounded to battery. Same .41v at the pink wire. 2.4 at yellow wire grounded to battery.
Old Oct 17, 2018 | 12:17 AM
Check Eng fuse 4. 15A
Old Oct 17, 2018 | 09:15 AM
Drspencer's Avatar
5 Year Member
Guy thinks he’s pretty smart. If my attachments would upload, I’d upload the 15A fuse that was blown at 4...
TAPyvehc93
Jul 20, 2018 08:42 AM
crashmymax
Feb 19, 2016 05:21 PM
jjc839
27
Jun 22, 2012 03:02 PM
work in progress
Sep 28, 2002 01:09 AM
