temp gauge not reading after fan install
Old Sep 26, 2002 | 01:11 PM
11 Second Club
Default temp gauge not reading after fan install
I did my fans last night and ran out of time, so I quickly wired them hot with 30 amp inline fuses. The temp gauge worked fine with this setup on the drive into town, but died on my way to lunch. It reads fine for the first 45 seconds then drops to 160, and this is with out the truck running or just turning the key on. I am going to wire in relays this after noon and later I am going to wire into the PCM. Has anyone had this problem? I am sure it will go away when I rewire, but I would like to know what caused it.
Thanks
Kevin
Old Sep 26, 2002 | 01:20 PM
GREGGO's Avatar
Default Re: temp gauge not reading after fan install
Not sure, I never came near the t-stat, sensors or gauge on my fan install. Did you tie into the t-stat sensor?
Greg
Old Sep 26, 2002 | 01:25 PM
11 Second Club
Nope, just ran from the fan to switch to power source, and fan to ground. weird
Old Sep 26, 2002 | 04:31 PM
RED2K's Avatar
damn, must be some good fans to cool it like that. lol <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Sep 26, 2002 | 06:58 PM
JWRENCH's Avatar
After you finish the job I'd try to get the thing on an autotap to see exactly what's going on with the gauge. On a good day mine is only about 15 degrees off of the actual temp.
Old Sep 26, 2002 | 08:43 PM
11 Second Club
Rewired fans to the fuse box and gauge works fine now. I still don't understand what the deal was, but everything is fine now.
Old Sep 27, 2002 | 02:18 PM
Scream's Avatar
MOOBIES Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by work in progress:
<strong>Rewired fans to the fuse box and gauge works fine now. I still don't understand what the deal was, but everything is fine now.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I originally wired mine to my fuse box, but you need to be careful not to overload any circuits! There are these things called multiplexes (I guess that it ties more than one system together) and (according to my car stereo buddy that fixed it for me) you can pop fuses and overload systems easily!
After I put my fans on, my A/C didn't work, truck would keep running after you turned the key off and took it all the way out(!) and an assortment of other little things...all because I blew a 10amp fuse!
Just make sure that you're not overloading any circuits!
Old Sep 27, 2002 | 04:50 PM
11 Second Club
Everything works fine now
Old Sep 28, 2002 | 01:09 AM
graygmc's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Scream:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by work in progress:
Just make sure that you're not overloading any circuits!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">so how do you have yours wired up now? are the wires still running to the fuse box?
Oobray
Jun 13, 2022 03:38 AM
Matt C.
Aug 1, 2015 01:25 PM
dantheman1540
Jul 29, 2015 04:45 PM
Nimoryan
Jul 5, 2015 03:50 PM
