LC-1 Output Question
Old Nov 22, 2011 | 01:14 PM
Steve-O-08's Avatar
Default LC-1 Output Question
Does anyone know if the LC-1 Wideband has a 0-1v analog output?
I was trying to pull up the manual and I wasn't having any luck finding it.
Old Nov 22, 2011 | 01:17 PM
Atomic's Avatar
I have a gauge for that
If it does have an analog output it is probably 0-5v
Old Nov 22, 2011 | 01:21 PM
2007chevy5.3l's Avatar
I believe Atomic is right.
Old Nov 22, 2011 | 01:41 PM
Steve-O-08's Avatar
I thought I read a post on tech that someone used it to replace a factory narrow band sensor, but can't find the posting. Anyone done this before? Just curious.
Old Nov 22, 2011 | 02:03 PM
02'Z71ONDUBZ''s Avatar
you can download the LC1 manual from innovate's website, the pdf is too large to attach on here. I believe it is 0-5v output to be used with tuning software.
Old Nov 22, 2011 | 06:44 PM
chpspecial's Avatar
The lc1 has two analogue outputs. Both are user programmable to be either 0-5v wideband use or 0-1v narrow band simulator.
Old Nov 22, 2011 | 07:09 PM
Gadgetized's Avatar
I could not tell you how many hours I spent looking up the way to do what you are talking about. Supposedly it can be done, but I couldn't find anyone that had actually done it, or how to hook it up that way. If you can figure it out, it would be perfect sticky material. It would be nice to install a WB in place of the NB, and run both. You could WB tune without having to weld in an extra bung.
Old Nov 22, 2011 | 09:59 PM
blue0453's Avatar
How to Setup Your Wideband in Hp Tuners - HP Tuners Bulletin Board
Old Nov 24, 2011 | 12:20 AM
Alpinestar's Avatar
When you say "replace the factory narrow band sensor" do you mean hook it up directly to the PCM or are you just trying to hook the narrow band up to efi live/hp tuners?
andrewlong
Nov 9, 2016 09:38 AM
andrewlong
Sep 8, 2015 10:25 PM
Forcefed81
Sep 8, 2015 10:02 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
iregret
Sep 7, 2015 01:20 PM
