Interceptor gauge?
Old Jul 16, 2006 | 03:15 PM
00blackz71's Avatar
Default Interceptor gauge?
I just installed the interceptor scan gauge and I am trying to read it. I have no clue what some of the functions mean or what exactly I should be looking at. I am having trouble getting my nelson tune done right. Nelson reccommended I get this gauge. What should I be looking for and how do I know what a normal reading is? I drove for about 10 min watching the timing and retard today. I couldn't do any WOT runs but at about 60mph when it downshifts into drive I am getting up to 8* of knock retard and about 20* timing. When it shifted into OD it dropped to 15* but no KR. Just sitting idleing the timing jumps anywhere from 15*-35* and it read in the 40's going down the driveway. I don't know for sure but that doesn't sound right to me.
Old Jul 16, 2006 | 06:07 PM
TIM Z's Avatar
11 sec. Truck Mod
let him know what your o2 bank 1 and 2 read at WOT. should be around 920 for a safe A/F ratio. Also he needs to see timing and KR at WOT. ALSO let him know what your Air Intake Temps are while you are recording the other values.
Old Jul 16, 2006 | 06:58 PM
00blackz71's Avatar
So do I need to start from a dead stop and go WOT or does it matter? How long do I need to hold WOT?
Old Jul 16, 2006 | 07:07 PM
TIM Z's Avatar
11 sec. Truck Mod
you can just drive normal and punch it and get your values, just hold WOT for a few seconds but make sure you shut her down if your O2 reads 890 or below and if your gettingf knock retard shut it down quick and let your tuner know .
Old Jul 16, 2006 | 09:01 PM
00blackz71's Avatar
I haven't tried the record yet so I am not sure how it works. If I set the gauge to record, will it tell me everything I need to know or do I actually need to watch the gauge and write the info down?
Old Jul 17, 2006 | 07:30 PM
03sierraslt's Avatar
Well first of all what is your setup? Forced induction or not? If not then you will not have 02 readings in the 900's. What are you mods?
Old Jul 17, 2006 | 07:56 PM
00blackz71's Avatar
Only mods are a cam and veraram intake. This morning I held it at WOT and got these numbers. Knock retard/o2 : 3.3/890, 3.6/875, 3.4/895, 3.3/890, 3.7/905 at 73*IAT. Nelson mention that he wanted to also see what the maf was reading. This afternoon I checked that. KR/maf lb/m : 7.5/28.99, 7.3/26.90, 7.2/28.99 7.9/22.69 at 104*IAT. The first run was started at 60mph and second at 40mph if it makes any difference. Is this enough info to give nelson a call or should I try to get more?
Old Jul 17, 2006 | 07:57 PM
TIM Z's Avatar
11 sec. Truck Mod
i assumed you were F I.
Old Jul 18, 2006 | 01:07 AM
Wheatley's Avatar
Truck Sponsor
Definaly give Nelson a call man,he will help you out.Allen is an awesome guy
Old Jul 18, 2006 | 01:21 AM
goshawk23's Avatar
Truck addict
i have the same scan gauge. check ltrms on both banks under wot. record the number. check knock retard under wot. check the number. then look at timing and o2's under wot. report the data back to him. this gauge will record data but i haven't used it that way yet.
Texas5.3_1251
Mar 5, 2016 08:10 PM
dantheman1540
Feb 24, 2016 09:56 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
zblee
Sep 17, 2015 07:58 AM
kmcn47
Sep 17, 2015 01:12 AM
