I'm Rich!
My offset table is at 13.5v 0.43945. Someone gave me these numbers after they had 60lb injectors flow tested. I have them in my 5.3 n/a running close loop for right now and my LTFT are still a bit off in the low teens, but I think its due to a ect problem havent had time to tune again.
Ever since installing the charger way back when, I've only had 52 psi of fuel pressure. I was going to adjust the FPR to get to 58 psi but had an extra FPR laying around and put it in today. Wohoo 58psi... just where it should be.
I also took the time to test my Autometer FP Gauge. I've verified that it is now reading about 11 psi to low. Sending it in to Autometer to fix. Once I get the gauge back in and working I'll start some serious tuning... errr screwing around in my case
I started at .458 for the 13.5 row. These numbers were given to me by the tuning GURU in KY. I'm now at .504 and its idling a little better. I haven't spent any time at all working on it because of a couple other issues I wanted to straighten out before I went to far.
I can't believe I let the fuel pressure thing go on so long. It worked so I didn't touch it. Now chances are my VE table will be off with the FP change. PCM was calculating fuel based upon a bad IFR table. Flowing less fuel so my VE is wrong to the high side. Thinking I can adjust by a % from Old IFR to New IFR and keep that in mind for AFR error.
This new tuning project is going to be fun.
You know if you look at a % sign long enough it looks like 96
I really have never liked tuning the truck. Its to tedious for me. I'd rather go out and spin a wrench. Plus now its damn expensive. If it take me the miles it took me to tune the VE I'll have to take out a loan for the fuel!
bk_cauley
40
Aug 17, 2018 05:45 PM
Cowboy Tom
24
Feb 11, 2017 08:20 PM
no doubt!
