Idle surging after driving then dies
Old Apr 17, 2009 | 12:34 PM
kylem's Avatar
Default Idle surging after driving then dies
My truck has all the bolt ons, 220 cam, 9.5 3800 stall. The problem started after the converter got put in a few months ago. The truck will start surging(rpms start to jump up and down) real bad and will want to shut off if i do not put it in neutral and give it a little gas. It will only do it after i drive for a while with out a lot of stop and go, like if i get on the interstate and drive for like three exits and then get off and stop at a red light. It will also do it if i pull in a parking spot and give it a little gas and let of quick to hit the brake. I also noticed sometimes while waiting in traffic it will start to surge for about 30 seconds and then stops.
I had a friend raise the base running air flow but when i start the truck it flares up to 2500 rpm then back down. It helped a little but there has to be a better way to fix it. I am going to get the file, i do not have it right now.
Thanks for any help
KyleM
Old Apr 17, 2009 | 12:53 PM
sonoma43's Avatar
sounds like your idle airflow table isnt tuned right...
Old Apr 17, 2009 | 04:30 PM
kylem's Avatar
I wish i had the file so everybody can see it, i am just waiting on my friend to send it to me.
Old Apr 17, 2009 | 06:10 PM
KLUG'S SS's Avatar
FormerVendor
The idle airflow needs to be tuned the correct way after your ve and maf are tuned.
After a cam swap to get the car or truck idling on it's own I add 2-3 g/sec to the whole idle airflow table for starters then I tune the ve and maf to get my trims within 3% and then do some RAF tuning which takes a little time and patience if you want to do it right and have a good idle.
Old Apr 18, 2009 | 02:40 PM
kylem's Avatar
Here is the thread my friend started on HPTuners forums. The file is on the first post. http://www.hptuners.com/forum/showthread.php?t=23013
Old Apr 18, 2009 | 03:33 PM
v8
17,16,15,14,13,12,11 Drvr
did you try that tune out that was posted up for ya?
Old Apr 18, 2009 | 03:39 PM
BlackGMC's Avatar
Resident Retard
Sounds like the desired airflow table like others have mentioned, also you will need to look at the Throttle Cracker table...
Old Apr 18, 2009 | 05:45 PM
kylem's Avatar
Not yet i have not got back down to Orlando.
Thanks
He said that we are going to change the airflow table next time i come down. I will mention the throttle cracker.
Thanks
Old Apr 18, 2009 | 08:14 PM
Wilde Racing's Avatar
How do I change this text
Is this truck "drive by wire" or does it have a cable?
Old Apr 19, 2009 | 12:50 AM
kylem's Avatar
Sorry i forgot to post the year but the truck is drive by wire. It is an 06 5.3HO.
