idle afr
Old Feb 18, 2008 | 10:41 AM
TURBHOE's Avatar
Default idle afr
how low is too low? at what point does too rich start to wash stuff out? i can't gt my idle leaner than 10.5-11.5 with out missfireing.
Old Feb 18, 2008 | 10:44 AM
BlackGMC's Avatar
Resident Retard
IMO if your runing 10.5-11.5 at idle then you have something mechanically wrong,,, Mine sits at 14.9 all day long with no problems.... What timing are you running at idle?
Old Feb 18, 2008 | 12:01 PM
WorkTruc's Avatar
Old Feb 18, 2008 | 01:45 PM
TURBHOE's Avatar
sorry for the confusion. i installed new injectors. they are fat slow pigs and will misfire if the PW is below 2.5ms. the truck wil buck and die and all sorts of things if i go below 2.5-2.6ms. timing is around 20 at idle.
Old Feb 18, 2008 | 01:47 PM
jakebdb56's Avatar
I'm assuming you've tuned your VE at idle?
Also, what is in your running airflow idle tables?
Old Feb 18, 2008 | 01:49 PM
TURBHOE's Avatar
shouldn't have to change that for just new injectors. here is a tune and a log
File Type: hpt
File Type: hpl
Old Feb 18, 2008 | 02:38 PM
03sierraslt's Avatar
What injectors are you running? 50lb's? Your offset table is high and your Min pulse is pretty high as well. I can get my 60lb Seimens (72's) to a 1.6pw
Old Feb 18, 2008 | 02:43 PM
TURBHOE's Avatar
yeah the 50lber's. wierd thing i don't know if you seen in the log but my left bank is leaner than my right. i just swapped the WB around to the left side and it confirmed it. if i lower the offset and the min pulse tables the truck goes WAY lean as in the wideband can't detect it lean. and it sounds like its camed. bucking and coughing and all kinds of goodness. it will also die when you come to a hard stop or blip the throttle.
Old Feb 18, 2008 | 02:45 PM
TURBHOE's Avatar
can injector angle in the manifold cause a lean affect?
Old Feb 18, 2008 | 03:04 PM
TURBHOE's Avatar
why do i keep getting LEAN dips on the left bank and not on the right? WTF maybe if i could get them to idle together i could lean it out some. but the left bank try to make the computer add fuel and when it does the left bank goes way rich. i tightened all of the exhaust manifold bolts. and am pulling about 2" more vacuum with my new injectors than my old.
