idle afr
sorry for the confusion. i installed new injectors. they are fat slow pigs and will misfire if the PW is below 2.5ms. the truck wil buck and die and all sorts of things if i go below 2.5-2.6ms. timing is around 20 at idle.
yeah the 50lber's. wierd thing i don't know if you seen in the log but my left bank is leaner than my right. i just swapped the WB around to the left side and it confirmed it. if i lower the offset and the min pulse tables the truck goes WAY lean as in the wideband can't detect it lean. and it sounds like its camed. bucking and coughing and all kinds of goodness. it will also die when you come to a hard stop or blip the throttle.
why do i keep getting LEAN dips on the left bank and not on the right? WTF maybe if i could get them to idle together i could lean it out some. but the left bank try to make the computer add fuel and when it does the left bank goes way rich. i tightened all of the exhaust manifold bolts. and am pulling about 2" more vacuum with my new injectors than my old.
