IAT's
Old Sep 22, 2008 | 03:19 PM
  #31
silver-mod-o's Avatar
Hunt&Fisherator
Sounds like you were just a bit heat soaked....
Old Sep 24, 2008 | 03:15 PM
  #32
rst06rado's Avatar
Anybody?
Old Sep 29, 2008 | 09:55 AM
  #33
rst06rado's Avatar
Can somebody help me? What is installation like with this sensor? Search did not work for me.
Old Oct 3, 2008 | 07:53 AM
  #34
rst06rado's Avatar
Please help me guys! Is the stock IAT sensor built into the MAF? If so which two wires do I need to use? There are 5 wires if I am correct? I believe I need the tan wire and one of the two grounds. Is this correct?
Old Oct 3, 2008 | 08:13 AM
  #35
nonnieselman's Avatar
You can put it anywhere in the intake tube..
The black and brown wires go to the IAT built in the MAF..
Just run them to your new IAT..
Old Oct 3, 2008 | 08:25 AM
  #36
rst06rado's Avatar
Awesome. Thank you!
Old Nov 19, 2008 | 01:00 PM
  #37
SRT10KLLR's Avatar
Former Vendor
Will the MSD 2320 work without splicing on the Caspers MAF/IAT breakout harness? Last time at the track my IAT's were 150F and the PCM was pulling a lot of timing because of it.
Old Nov 19, 2008 | 01:13 PM
  #38
zippy's Avatar
You can change that in the calibration as far as how much timing it pulls. On the other hand you want it to pull timing if you are getting IAT's that hot.
Old Nov 19, 2008 | 01:31 PM
  #39
SRT10KLLR's Avatar
Former Vendor
Exactly, I would much rather see real temps than lower how much the PCM pulls. Although running that high a temp might not need that much timing removed. I would have to run those temps and see how much timing it needs and adjust those tables. But that would require a lot of work on the dyno with no fan in front to try and get my real air temp in that range or put a blow drier in the air stream, lol.
GMCtrk
Jan 27, 2016 06:47 PM
Mr. Chainsaw
Oct 18, 2015 08:00 PM
JordanH
Oct 3, 2015 03:59 PM
dantheman1540
Sep 18, 2015 03:03 AM
TAPyvehc93
Sep 17, 2015 10:10 AM
