IAT resistor mod
Old Dec 25, 2011 | 10:51 AM
6789olds's Avatar
Default IAT resistor mod
just finished the Iat mod useing a 5 pin relay and a resistor to pull 3 degrees of timming for the nitrous . works great found the thread over on tech,and decided to give it a try .
Old Dec 25, 2011 | 11:52 AM
charcoal03silvy's Avatar
more details please!
Old Dec 25, 2011 | 12:09 PM
6789olds's Avatar
i used a 1/2 watt 560ohm resister so when my nitrous is armed the computer thinks the air temp is 140* and pulls out 3 degres . total cost was under 20 bucks .
Old Dec 25, 2011 | 12:45 PM
lsxnation's Avatar
Banned
nice mod, i might give it a try.
Old Dec 25, 2011 | 03:25 PM
smokeshow's Avatar
Mod with training wheels
Pretty neat little setup.
Old Dec 25, 2011 | 03:32 PM
6789olds's Avatar
seems to work pretty good wen i arm the nitrous the relay switches over to the resister and the air temp reads 140 then it reduces the timming by 3 degrees .then u can have your tune customized to pull what ever u need .I am running 26*off nitrous then 23* on the nitrous .
Old Dec 25, 2011 | 05:46 PM
Beatdown Z's Avatar
Laid Back
What the hell is a trim pot?
Old Dec 25, 2011 | 07:47 PM
MikeGyver's Avatar
A potentiometer, like a volume control on a guitar. It acts as an adjustable resistor. Usually those little ones mounted on a circuit board are called trim pots (potentiometers). Those look like a little box with an adjusting screw.
madmann26
Apr 29, 2020 09:17 AM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
bisqikss
Sep 27, 2015 09:40 PM
GM1697
Sep 9, 2015 10:31 PM
