IAC motor and plunger came apart!
Old Oct 15, 2011 | 05:01 PM
12sec.5.3's Avatar
Default IAC motor and plunger came apart!
Hello to all of my long lost buddies! I decided to give the truck some TLC today and of course i ran into a little pickle. I took the IAC off of the TB to try and diagnose some idle issues I've been having. I set it down and turned on the ignition and the damn thing pops off and flies halfway across the yard. I can get it back together but it won't suck in the plunger enough to fit back in the TB. Wt do I do, besides just getting another one..?
Old Oct 15, 2011 | 05:12 PM
MikeGyver's Avatar
It seems like I pushed mine in by thumb, but I'm not positive it was so long ago.
Old Oct 15, 2011 | 07:04 PM
kbracing96's Avatar
If I remember right, you should be able to hold it in and cycle the key a couple times to get it to retract till you can get it back in. Then when you turn on the truck, it will find it's park position.
Old Oct 15, 2011 | 08:41 PM
oldred95's Avatar
On my 95 I was able to wiggle the pintle side to side and gently push the pintle back in. Should be the same principle on yours but I wouldn't bet the farm on it working either. You could get a pin out of the connector and jump your motor A and motor B circuits to power and ground and suck it in. Anyone know what voltage an IAC runs at? I would assume 12 volts but to be honest I've never had a reason to test for it.
Go5.3tt06
25
Sep 4, 2016 10:25 AM
chvy=power
Oct 20, 2015 09:08 AM
bisqikss
Sep 14, 2015 10:13 PM
03chevytruck
Sep 14, 2015 09:15 PM
