hptuners scan help
Old Feb 5, 2007 | 09:01 PM
00blackz71's Avatar
Default hptuners scan help
I posted this on hptuners website but I didn't get any answers. Can someone look at my scan and tell me if they see anything wrong or if there is something else I need to do.
My 2000 z71 5.3 seems to not have as much power as it should. It has lt headers and a torque cam and tuned and locked by nelson so I can't get into the pcm. I didn't have hptuners at that time but I do now.
I don't have a wideband yet.
File Type: hpl
File Type: hpl
File Type: hpl
Old Feb 5, 2007 | 09:17 PM
shimp's Avatar
I can't get your scan files to download. They are trying to download as .htm files.
Maybe try zipping them up and then attaching them. Or I'll go look at the HPTuners site and get them from there.
Old Feb 5, 2007 | 09:29 PM
foff667's Avatar
LS1TECH Sponsor
just do a save as & rename them as hpl
Old Feb 5, 2007 | 09:33 PM
foff667's Avatar
LS1TECH Sponsor
i dunno man, a couple of two minute part throttle logs don't really help a whole lot...I will say your trims are pretty far off, but that could be due to any number of things.
Old Feb 5, 2007 | 10:14 PM
00blackz71's Avatar
What kind of log do I need to do? Part throttle is mostly where the problem is. It is bad enough that I quit driving it about 4 months ago. I need to get a god log to send to Nelson.
Old Feb 5, 2007 | 10:39 PM
foff667's Avatar
LS1TECH Sponsor
i dunno man, your telling us you think its down on power...many cams loose power over the stocker below 2 or 3 thousand rpm's so yeah maybe you did loose power down there...not sure what your question is other then that....thats one of the drawbacks with many cams is that you'll loose some low end for top end hp. Didnt look like you spun any higher then 3000 rpms in those logs so I would say its going to feel less powerful then the stock cam.
Old Feb 6, 2007 | 07:19 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
What have you done to the truck besides just add a cam? What are the cam specs?
Old Feb 6, 2007 | 07:20 PM
00blackz71's Avatar
I put in a cam for more pulling power not top end. I have a vinci ultra torque cam. Specs are 210/218 .551/.551 116 lsa 48* overlap, crane 1.8 rockers, 2600 converter. I hauled a 4 wheeler in the bed and had to put it in drive because it wouldn't stay in overdrive. Any slight hill it would downshift. Any chance the 1.8 rockers can be causing this?
Porscharu914
14
Jan 20, 2016 10:45 AM
Avalanche2002
Nov 30, 2015 07:31 AM
legerwn
56
Nov 15, 2015 10:21 PM
muncie21
Sep 7, 2015 09:55 PM
