HPT or EFILive guys help!
Old Jul 1, 2007 | 03:05 PM
kbracing96's Avatar
That table represents the max amount of timing it CAN pull. Generally timing is only affected when the AC clutch is in the act of engaging or disengaging. You need to log all the spark pids to see what if anything is actually pulling timing. I would start there rather then randomly 0ing out tables.
Old Jul 1, 2007 | 03:28 PM
99Silver6.0's Avatar
Originally Posted by kbracing96
That table represents the max amount of timing it CAN pull. Generally timing is only affected when the AC clutch is in the act of engaging or disengaging. You need to log all the spark pits to see what if anything is actually pulling timing. I would start there rather then randomly 0ing out tables.
Already in the process. But I logged and the A/C does pull timing. Im just messign around with stuff.
Old Jul 1, 2007 | 04:10 PM
gmforlife's Avatar
i just set my a/c cut off at a certain rpm, cause i like it on cruising, but when i go over 5000 rpm, it means i really don't want the a/c on, so i have it kick off at that exact rpm, and re-enable at that rpm also.
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
