How to disabl tcs???
Old Dec 26, 2008 | 06:20 PM
0235SS93's Avatar
Default How to disabl tcs???
When I spin my tires, the motor cuts out, like the tcs is on. My truck doesn't have a tcs switch, but i think the truck that the motor and pcm came out of did have one. Is there any way I can set it where my tcs is off all the time. I have HP Tuners and found a table called "TCS Method: Retard vs. RPM" in the general transmission settings. Could I zero out that table to turn it "off"?
Old Dec 26, 2008 | 06:41 PM
wastedrubber's Avatar
you gotta turn down your torque management, depending on your trans if it's a 4L60 i'd leave a little bit on
Old Dec 26, 2008 | 06:55 PM
0235SS93's Avatar
I've already taken out 75% of tm, but it still cuts out when you spin the tires full throttle. It acts just like my dad's Silverado SS when his tc is turned on. The motor/pcm came out of a V-MAX which I'm pretty sure had a TC switch on the dash.
Old Dec 26, 2008 | 07:40 PM
charcold-bowtie's Avatar
I dunno but there is engine torque management and tranny torque management. I honestly dunno what table u need to mess with.
Old Dec 26, 2008 | 07:43 PM
viciousknid's Avatar
Where's the Beef?
Search the HPTuners forum. It might be in there.
Old Dec 27, 2008 | 07:03 AM
KLUG'S SS's Avatar
FormerVendor
If you can post up your tune file I can help you take care of that.
Old Dec 27, 2008 | 12:07 PM
0235SS93's Avatar
Here ya go! Most of it is stock right now, just a few changes to transmission, fans and speed limiter. I'll finish the full tune when the weather around here clears up.
Old Dec 27, 2008 | 12:35 PM
kbracing96's Avatar
I'd try your engine abuse table, looks like they're still active. Max the RPM and Min the MPH.
Old Dec 27, 2008 | 03:29 PM
0235SS93's Avatar
I tried that along with zeroing that tcs table I found and that fixed it! Thanks guys!
MA$TER_E
Sep 9, 2015 03:14 PM
slowmo934
Sep 9, 2015 12:24 PM
lxcoupe
Aug 31, 2015 05:49 PM
1979rs/z28
Aug 24, 2015 08:43 AM
Suburbazine
Aug 9, 2015 01:17 AM
