How to disabl tcs???
When I spin my tires, the motor cuts out, like the tcs is on. My truck doesn't have a tcs switch, but i think the truck that the motor and pcm came out of did have one. Is there any way I can set it where my tcs is off all the time. I have HP Tuners and found a table called "TCS Method: Retard vs. RPM" in the general transmission settings. Could I zero out that table to turn it "off"?
you gotta turn down your torque management, depending on your trans if it's a 4L60 i'd leave a little bit on
I've already taken out 75% of tm, but it still cuts out when you spin the tires full throttle. It acts just like my dad's Silverado SS when his tc is turned on. The motor/pcm came out of a V-MAX which I'm pretty sure had a TC switch on the dash.
I dunno but there is engine torque management and tranny torque management. I honestly dunno what table u need to mess with.
Search the HPTuners forum. It might be in there.
If you can post up your tune file I can help you take care of that.
Here ya go! Most of it is stock right now, just a few changes to transmission, fans and speed limiter. I'll finish the full tune when the weather around here clears up.
I'd try your engine abuse table, looks like they're still active. Max the RPM and Min the MPH.
Originally Posted by kbracing96
(Post 4085825)
