Holley Dominator ECU?
Old Jan 18, 2017 | 08:18 PM
  #31
kbracing96's Avatar
You would have to add a separate ECT sensor. You can't share them because they are resistant operated. A MAF isn't used with the Holley. SD uses MAP, VE, RPM and throttle position for primary fuel calculations. Alpha_n (numeric) just uses throttle position and rpm for fuel calculations. This helps engines with large cams, mostly at idle when the vac (MAP) is bouncing all over the place and very low, to get a steady supply of fuel.
Old Jan 18, 2017 | 08:45 PM
  #32
MikeGyver's Avatar
Thanks
Old Jan 19, 2017 | 08:44 AM
  #33
DrX's Avatar
DrX
Originally Posted by MikeGyver
I don't know what this means, I am wondering if the Dominator uses MAF. Another question concerns sensors that both the stock PCM and the Dominator need. The only one that I can think of, when the PCM is controlling everything besides the engine, is ECT. Could it be piggybacked, or would another sensor need to be added? What else would need sharing in a setup that the stock PCM is controlling the trans?
No MAF and the Dominator can control a 4L60E or 80E.
Old Jan 19, 2017 | 10:25 AM
  #34
TXsilverado's Avatar
I would have one if they came down about a grand in price. last time I priced everything out I think I had 3,200 worth of crap in my cart.
Old Jan 19, 2017 | 07:44 PM
  #35
MikeGyver's Avatar
It is just fantasy for me, too, because of the price. But in my fantasy I would have the stock PCM control the trans to save money by not buying their trans harness.
But how would this be possible if the Dominator is hogging all of the engine sensors?
Doesn't the trans use ECT, for example, to raise the shift points when the engine is warm for faster warmup? And wouldn't it use the crank sensor for RPM?
Old Jan 20, 2017 | 09:22 AM
  #36
DrX's Avatar
DrX
Don't think ECT is used for the trans, just trans temp. Both heads have the ECT ports anyway. I would think you could split the crank and cam signals as long as both ECUs are sharing a common ground. MAP and IAT are easy to add more sensors if you needed them.
Price is more painful in Canadian dollars. This was my Dominator order list.
File Type: pdf
Old Jan 21, 2017 | 08:07 PM
  #37
MikeGyver's Avatar
That's a lot of money. Hurry up with your build so we can hear your experiences with the Dominator.
thewrx
Oct 6, 2015 10:59 AM
sTNT971
Sep 26, 2015 04:22 PM
The Sgt
Sep 24, 2015 08:06 AM
supershift67
Sep 18, 2015 08:21 PM
ZxHybrid
Sep 18, 2015 04:44 PM
