Help. Urgent!!!
Old Jun 14, 2016 | 03:31 PM
  #51
Wolftrk99's Avatar
Or maybe something shorted somewhere??
Old Jun 14, 2016 | 04:15 PM
  #52
1FastBrick's Avatar
Custm2500's Rude Friend
Originally Posted by About20ninj45
Thats the thing, it doesnt matter what fusses are pulled, something is dropping the voltage from 13 volts to less than 9 during a read/write procedure.. maybe i have a bad ground somewhere...
Has the engine been out?
Old Jun 14, 2016 | 05:47 PM
  #53
About20ninj45's Avatar
No. Not at all. Original engine
Old Jun 14, 2016 | 06:53 PM
  #54
tim wellington's Avatar
Default long shot
dbw check your accelerator -inside truck ,I was reading tune in 03 .I hit the accelerator by mistake voltage drop and it stop reading ,like I said long shot
Old Jun 14, 2016 | 06:59 PM
  #55
Yea I didn't touch anything. I'm going to put up a video on YouTube so you guys can see what time talking about.
Old Jun 14, 2016 | 07:23 PM
  #56
Where are you taking that voltage reading? You can't rely on the dash volt meter. Dash gauges will typically drop when normal reading or writing is going on.
Old Jun 14, 2016 | 08:53 PM
  #57
Dash... The meter drops and the truck power cycles during read. Nothing is screwy with my aldl wires either. I'm at a loss. Suqs *** that I have to save logs and tune the other pcm instead of doing it in the vehicle
Old Jun 14, 2016 | 11:10 PM
  #58
What does this mean?
Again data to the cluster is interrupted during read and write. What the gauges display mean nothing.
Old Jun 14, 2016 | 11:46 PM
  #59
Wolftrk99's Avatar
The guages sweep during read and write in my 99 to signify certain points in the process, when its done it momentarily cuts everything off.... Only time ive had issues with it not wroting completely was when i thiught i had it plugged in all the way but didnt quite have it plugged in all the way...
Old Jun 14, 2016 | 11:50 PM
  #60
Wolftrk99's Avatar
Wonder if there isnt a terminal at the aldl that isnt spread or corroded or something!!!
