Help!! No start after tranny install
Originally Posted by DrX
I was pretty rough on that too. Much easier after I remembered to remove the oil dipstick tube.
Originally Posted by KySilverado
Looks like you have access to GM's service data also. I have this and other information printed out, ready for my next jaunt under the truck. Thanks for the post!
Really a bad day... will be a while before I get back at it. The truck had me bummed out... right after posting this thread I received a call. My father passed away this morning.
Finished up all the funeral details today. To get my mind off things I crawled back under the truck. Found I had broken the 12V signal wire to the CPS. Soldered it back up and the truck fired right up. Starter didn't sound good.. I've heard starters that sound like it. Kinda like it is grinding as it cranks.
Anyway started filling up the tranny with fluid. As it warmed up started making the scrapping/wheezing sound. This is the "worse" sound it started making before I shut it down for the tranny install. No noise from underneath at least. Still didn't pinpoint it but sounds like maybe the passenger valve train area. Shut it back down to let it cool back off. Went to start it again and the starter just ground but didn't turn over. Do they still make shims for starters? I am really getting frustrated with things.
After the funeral I'll did back into it. My hearts just not in it now.
hang in there , youll get her done, Im very sorry for your loss,was your father into cars/trucks? howd he like your supercharged truck? hope everything else works out for you, our prayers are with you.
Thanks for the kind words and prayers Tim. I will get the truck going. Just doesn't seem so important now.
Drove the truck about 5-6 miles today. As I posted above the no start was a cut wire to the Crank Position Sensor. Found I didn't tighten up the starter well after fixing the CPS wire. That was the starter grind problem. Still have the strange noise going on so I'm not going to drive it until I get it figured out. Must be something in the engine. Might be time for a new 6.0 longblock.
The new tranny worked well. Of course I haven't got much time on it but it shifted nice and firm on a couple part throttle pulls. Much better than my stocker with transgo.
GMCtrk
38
Aug 9, 2015 08:50 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
