Help.... Ls2 Cyl. 5 and 8 Multiple misfires P0300
Old Sep 17, 2012 | 09:18 PM
Bigschwerm's Avatar
Default Help.... Ls2 Cyl. 5 and 8 Multiple misfires P0300
Please Read all before you answer.....I tried everything I can think of.
Here's the facts: 05 LS2 GTO 6 Speed New GM Crate Motor 6000 miles
Only Mods are Cold Air Intake and Muffler Delete Stock Tune.
Swapped injectors from cylinder to cylinder, All New Coils, New Wires,
Tr55 Plugs gapped to .057", New Delco O2 sensors, Valve springs are
good, Push rods not bent, No bent valves, Leak down test is perfect,
perfect compression.
Car will miss heavily at around 1900 to 2200 rpm's on cylinders 5 and 8
only verified with HP Tuners scan. Doesn't really feel like it really and
really can't hear it in the exhaust note. Car doesn't lug or have any lack
of power??.
All the plugs look great and there is no Knock. Im thinking its gotta be
electrical? Car does Idle a little rough at times though...maybe im
paranoid though.
Here is what my possible next steps are:
1.Replace the Crank Position sensor and perform a case learn?
2. Cam Sensor??
3. Any Ideas or suggestions please feel free to share....????
Old Sep 17, 2012 | 09:44 PM
Bigschwerm's Avatar
After reading through hundreds of threads ect...
Driveline Vibration IE: Flywheel / driveshaft ect.... MIGHT be a good bet because it
only does it at the certain RPM's 1800 to 2200ish. Does that sound logical???
Old Sep 18, 2012 | 02:54 PM
Bigschwerm's Avatar
Up^^^
Old Sep 18, 2012 | 03:09 PM
Byrdman11's Avatar
So it show a misfire but dont feel like it misfire. What will it do if it in drive and you power brake it at the rpm u have the problem?
Old Sep 18, 2012 | 05:40 PM
Bigschwerm's Avatar
Update:
Thought I would post the results for future searches.
Installed Cam sensor and went 70 miles in the RPM range that is was throwing the code.....and the code did not come back. Before the code would pop up every 3 to 4 seconds while cruising in that range.
Hopefully this was it....crossing fingers.
Old Sep 18, 2012 | 06:33 PM
03sierraslt's Avatar
Thats good you found something, keep us updated after some more miles are on to verify.
Old Sep 19, 2012 | 07:06 AM
Byrdman11's Avatar
Good new!
Old Sep 20, 2012 | 01:31 PM
Bigschwerm's Avatar
Final Update:
The code did start coming back after 150 miles but not as much. I stopped at a GM dealer and had them perform a quick crank sensor relearn with there Tech II.
Low and behold the symptoms are totally gone. We couldnt get HP Tuners to perform the relearn for some reason?
bearden86
26
Nov 15, 2015 03:58 PM
Tydriver
45
Oct 23, 2015 09:19 PM
gmcyukon
Oct 5, 2015 06:20 AM
trxmxzx
Sep 29, 2015 07:42 AM
CammedZ71
11
Sep 9, 2015 02:05 PM
