Help on 4L80e tuning
Old May 31, 2011 | 01:32 PM
LS1FREEK's Avatar
13 Second Truck Club
Default Help on 4L80e tuning
I know all the little tips and tricks to tuning a 4L60e, but I was wondering if there is anything different to tuning an 80e? How much pressure can I run, tcc pwm's etc... I'll be tuning my brothers (jake99 on here) truck. Transmission will be a stock 4L80 out of an 05 Chevy van 2wd. Truck is a 99 RCSB with 4.560 gears and is making approx 500 crank HP and we will be running a 150 wet shot through it.
Also, I use EfiLive and will most likely be using a tune from HoldenCrazy.com, so which tune do yall recommend? I do need an OS that has an 80e installed right?
Old May 31, 2011 | 04:16 PM
Gadgetized's Avatar
Yeah, find an OS off of holdencrazy that is the same number as Jakes but with a 4l80e. Then just do a segment swap. I am not finished with how the way mine shifts, so I can't elaborate on that. If the tranny is out, it would be a perfect time for a shift kit.
Old May 31, 2011 | 04:39 PM
LS1FREEK's Avatar
Yup, shift kit has been installed. Segment swap, is that where I do a full reflash, and then just go back and do a cal only flash from the old tune?
Old May 31, 2011 | 04:47 PM
LS1FREEK's Avatar
Forget my last question, I just read it up on a sticky over at the EfiLive forum.
Old May 31, 2011 | 06:25 PM
TIM Z's Avatar
11 sec. Truck Mod
I used a 2000 6.0 4l80E base tune off holden crazy for my segment swap.
On EFI LIVE forum, There is a sticky by Blackbear. ( he might also be under DCJUSTIN) . Its so easy to do after reading.
I can give you a copy of my trans settings if that will help you get started. I have EFI Live also if ya didnt already fig. it out LOL
Old May 31, 2011 | 07:59 PM
Gadgetized's Avatar
If you did a shift kit, you want to leave your pressures.
Old May 31, 2011 | 08:05 PM
TIM Z's Avatar
11 sec. Truck Mod
I didnt and all is good, but pressures arent set to kill.
Oobray
Jun 13, 2022 03:38 AM
Silveradorst07
Dec 31, 2015 12:04 AM
Go5.3tt06
Sep 12, 2015 09:29 AM
noproblems209
Aug 10, 2015 06:57 PM
lxcoupe
Jul 14, 2015 10:14 PM
